Aller au contenu principal
AYL SoundFit Motherboard Replacement
Ce dont vous avez besoin
  1. AYL SoundFit Motherboard Replacement, Motherboard: étape 1, image 1 de 1
    • Unscrew the four hex screws on the top of the device using a 2.5mm hex screwdriver.
  2. AYL SoundFit Motherboard Replacement: étape 2, image 1 de 1
    • Place a spudger between the black plastic cover and the green case.
    • Remove the black cover away from the main casing and remove the cover.
  3. AYL SoundFit Motherboard Replacement: étape 3, image 1 de 1
    • Place the spudger tool between the black housing, which contains the woofer, and the outer rubber casing.
    • Remove the housing away from the body to reveal the motherboard, speaker, and battery.
  4. AYL SoundFit Motherboard Replacement: étape 4, image 1 de 2 AYL SoundFit Motherboard Replacement: étape 4, image 2 de 2
    • Remove the two Phillips screws which hold its battery casing on the housing using a PH00 Phillips screwdriver.
    • Remove the battery case to reveal the battery.
  5. AYL SoundFit Motherboard Replacement: étape 5, image 1 de 1
    • Using a soldering iron, heat up and remove both the positive and negative battery contacts from the motherboard.
  6. AYL SoundFit Motherboard Replacement: étape 6, image 1 de 3 AYL SoundFit Motherboard Replacement: étape 6, image 2 de 3 AYL SoundFit Motherboard Replacement: étape 6, image 3 de 3
    • Remove all three Phillips screws which holds the motherboard to the base using a PH00 Phillips screwdriver.
    • The motherboard can now be wiggled free from the base.
3 autres ont terminé cette réparation.
john
Membre depuis le 03/10/16
171 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team 3-3, Harley Spring 2016 Membre de l'équipe IUPUI, Team 3-3, Harley Spring 2016
IUPUI-HARLEY-S16S3G3
4 membres
5 tutoriels rédigés
3 commentaires
Where do u get a new motherboard at?
calvinsmith522 - Réponse
Anybody know where to get a motherboard?
David Whitman - Réponse
Where do I get a motherboard?
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 8
Total : 1,545
