Aller au contenu principal
AYL SoundFit Speaker Replacement
Ce dont vous avez besoin
  1. AYL SoundFit Speaker Replacement, Motherboard: étape 1, image 1 de 1
    • Unscrew the four hex screws on the top of the device using a 2.5mm hex screwdriver.
  2. AYL SoundFit Speaker Replacement: étape 2, image 1 de 1
    • Place a spudger between the black plastic cover and the green case.
    • Remove the black cover away from the main casing and remove the cover.
  3. AYL SoundFit Speaker Replacement: étape 3, image 1 de 1
    • Place the spudger tool between the black housing, which contains the woofer, and the outer rubber casing.
    • Remove the housing away from the body to reveal the motherboard, speaker, and battery.
  4. AYL SoundFit Speaker Replacement: étape 4, image 1 de 2 AYL SoundFit Speaker Replacement: étape 4, image 2 de 2
    • Remove the two Phillips screws which hold its battery casing on the housing using a PH00 Phillips screwdriver.
    • Remove the battery case to reveal the battery.
  5. AYL SoundFit Speaker Replacement: étape 5, image 1 de 1
    • Using a soldering iron, heat up and remove both the positive and negative battery contacts from the motherboard.
  6. AYL SoundFit Speaker Replacement: étape 6, image 1 de 3 AYL SoundFit Speaker Replacement: étape 6, image 2 de 3 AYL SoundFit Speaker Replacement: étape 6, image 3 de 3
    • Remove all three Phillips screws which holds the motherboard to the base using a PH00 Phillips screwdriver.
    • The motherboard can now be wiggled free from the base.
  7. AYL SoundFit Speaker Replacement, Speaker: étape 7, image 1 de 1
    • Using a soldering iron, heat up and remove the positive and negative wire contacts from the motherboard.
  8. AYL SoundFit Speaker Replacement: étape 8, image 1 de 1
    • Remove four Phillips #1 screws to detach the speaker form the module.
    • Extract the speaker from the body of the AYL SoundFit.
Sajal Kherde
Membre depuis le 02/16/16
107 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team 3-3, Harley Spring 2016 Membre de l'équipe IUPUI, Team 3-3, Harley Spring 2016
IUPUI-HARLEY-S16S3G3
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 9
Total : 637
