Aller au contenu principal
Abu Garcia Black Max Spool Replacement
  1. Abu Garcia Black Max Spool Replacement, Spool: étape 1, image 1 de 2 Abu Garcia Black Max Spool Replacement, Spool: étape 1, image 2 de 2
    • Make sure you take off all the line on the reels spool.
  2. Abu Garcia Black Max Spool Replacement: étape 2, image 1 de 2 Abu Garcia Black Max Spool Replacement: étape 2, image 2 de 2
    • Take the black pin and apply pressure, pushing the pin to the left until it cannot go further.
    • On the right side of the reel, pull the side panel towards you until it pops up toward you.
  3. Abu Garcia Black Max Spool Replacement: étape 3, image 1 de 1
    • Make sure you are still holding the pin to the left.
    • Slowly pull the side panel to the right until it comes off completely.
  4. Abu Garcia Black Max Spool Replacement: étape 4, image 1 de 1
    • Grab the spool with your fingers, and gently pull out the spool from the reel.
    • Grab your replacement spool and have it ready for the next step.
  5. Abu Garcia Black Max Spool Replacement: étape 5, image 1 de 1
    • Take your replacement spool and put the spool back inside the reel, the same way you pulled out the old spool.
  6. Abu Garcia Black Max Spool Replacement: étape 6, image 1 de 1
    • Make sure that there are no spaces in the left and right sides of the spool once the new spool is in.
  7. Abu Garcia Black Max Spool Replacement: étape 7, image 1 de 2 Abu Garcia Black Max Spool Replacement: étape 7, image 2 de 2
    • Pull the pin to the left again.
    • Place the black side panel back onto the reel.
    • Once the black side panel is back on, apply downward pressure, pushing the black side panel back, until it clicks into place.
  8. Abu Garcia Black Max Spool Replacement: étape 8, image 1 de 1
    • You have now done a complete spool replacement on the Abu Garcia Black Max baitcasting reel.
    • When you decide, you can now put the line back onto the spool.
Ligne d'arrivée
Daniel Minev
Membre depuis le 01/10/24
157 Réputation
1 tutoriel rédigé
Équipe
York University, Team 1-18, O'Regan Winter 2024 Membre de l'équipe York University, Team 1-18, O'Regan Winter 2024
YORK-O'REGAN-W24S1G18
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 12
30 derniers jours : 56
Total : 234
