Introduction
This guide will show you how to gain access to the LCD Control Board and the Backlight Control Board on an Apple Cinema Display M8149. The tools required for this section are the spudger and the PH 2 screwdriver.
Pièces
Aucune pièce nécessaire.
  1. Before starting, make sure the display is UNPLUGGED. Failure to do so can result in shock and serious injury. Flip the Cinema Display so it is on its face and the feet are pointed away from you. Using the PH 2 screw driver, unscrew the three feet screws (9.52 x 4.43mm).
    • Before starting, make sure the display is UNPLUGGED. Failure to do so can result in shock and serious injury.
    • Flip the Cinema Display so it is on its face and the feet are pointed away from you.
    • Using the PH 2 screw driver, unscrew the three feet screws (9.52 x 4.43mm).
    • Remove the back foot from the hinge mount by grabbing the foot and pulling upwards.
  2. Locate and remove the back plate screws (5.25 x 4.43 mm) using the PH 2 screw driver. Lift the back plate off of the display. Completely remove the back plate and set it aside.
    • Locate and remove the back plate screws (5.25 x 4.43 mm) using the PH 2 screw driver.
    • Lift the back plate off of the display.
    • Completely remove the back plate and set it aside.
  3. %Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
    Vous avez déjà réparé quelque chose ? Vous êtes un génie.
    Partagez votre réparation avec le hashtag #ImAGenius
    Nous sommes tous des génies
  4. With the PH 2 screw driver, remove the four rim screws (9.52 x 3.43 mm) located on the outer rim of the metal cover. Next, unscrew the four cover screws (11.91 x 2.89 mm) using the PH 2 screwdriver.
    • With the PH 2 screw driver, remove the four rim screws (9.52 x 3.43 mm) located on the outer rim of the metal cover.
    • Next, unscrew the four cover screws (11.91 x 2.89 mm) using the PH 2 screwdriver.
  5. Unplug the large plug that connects the control board to the rest of the display. Unplug the blue and gray plug  on the right side of the control board. Unplug the blue and gray plug  on the left side of the control board.
    • Unplug the large plug that connects the control board to the rest of the display.
    • Unplug the blue and gray plug on the right side of the control board.
    • Unplug the blue and gray plug on the left side of the control board.
  6. Lift the large metal cover which spans across the whole display. Lift the large metal cover which spans across the whole display.
    • Lift the large metal cover which spans across the whole display.
3 autre(s) ont terminé cette réparation.
Brett Murphy
Membre depuis le 01/04/2011
168 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 10-41, Forte Spring 2011 Membre de l'équipe Cal Poly, Team 10-41, Forte Spring 2011
CPSU-FORTE-S11S10G41
5 membres
6 tutoriels rédigés
thank you for this guide. my 22" adc didn't want to start up. after following this guide, it now works with my G4. thank you
thereddrag0n - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 19
Total : 4,421
