Aller au contenu principal
Accessing Logicboard
Ce dont vous avez besoin
  1. Accessing Logicboard, Front and Back Cover: étape 1, image 1 de 2 Accessing Logicboard, Front and Back Cover: étape 1, image 2 de 2
    • Remove the following screws:
    • Two silver 3.15mm Phillips #00 screws on the right side of the camera
    • Two silver 2.08mm Phillips #00 screws on the left side of the camera
  2. Accessing Logicboard: étape 2, image 1 de 1
    • Remove the two indicated screws on the bottom of the camera:
    • The screw circled in red is a longer silver 3.15mm Phillips #00 screw
    • The screw circled in blue is a shorter silver 2.25mm Phillips #00 screw
  3. Accessing Logicboard: étape 3, image 1 de 2 Accessing Logicboard: étape 3, image 2 de 2
    • Carefully pull the back of casing away from the front.
  4. Accessing Logicboard: étape 4, image 1 de 3 Accessing Logicboard: étape 4, image 2 de 3 Accessing Logicboard: étape 4, image 3 de 3
    • After removing the back cover, several things must be removed.
    • Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”.
  5. Accessing Logicboard: étape 5, image 1 de 2 Accessing Logicboard: étape 5, image 2 de 2
    • To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off.
  6. Accessing Logicboard, Logicboard: étape 6, image 1 de 2 Accessing Logicboard, Logicboard: étape 6, image 2 de 2
    • On the front of the camera, in battery case, remove screws indicated:
    • Two black 2.05mm Phillips #00 screws
  7. Accessing Logicboard: étape 7, image 1 de 2 Accessing Logicboard: étape 7, image 2 de 2
    • Flip the camera over to the backside and remove screws indicated:
    • The screw circled in red is a longer black 3.00mm Phillips #00 screw
    • The screw circled in blue is a shorter black 2.00mm Phillips #00 screw
  8. Accessing Logicboard: étape 8, image 1 de 1
    • Pull the cover plate off for the two power cord jacks.
  9. Accessing Logicboard: étape 9, image 1 de 3 Accessing Logicboard: étape 9, image 2 de 3 Accessing Logicboard: étape 9, image 3 de 3
    • Cautiously and gently pull up the control board at the upper left corner, next to the viewfinder.
  10. Accessing Logicboard: étape 10, image 1 de 1
    • Remove the orange tape on top of the SD cardholder.
  11. Accessing Logicboard: étape 11, image 1 de 1
    • Open the battery cover.
  12. Accessing Logicboard: étape 12, image 1 de 2 Accessing Logicboard: étape 12, image 2 de 2
    • Lift the indicated plastic piece off.
  13. Accessing Logicboard: étape 13, image 1 de 2 Accessing Logicboard: étape 13, image 2 de 2
    • Remove screws indicated:
    • Two black 4.80mm Phillips #00 screws
  14. Accessing Logicboard: étape 14, image 1 de 1
    • Unsolder points indicated.
    • Please refer to steps 1 through 6 of the Ifixit soldering guide to unsolder these leads.
  15. Accessing Logicboard: étape 15, image 1 de 3 Accessing Logicboard: étape 15, image 2 de 3 Accessing Logicboard: étape 15, image 3 de 3
    • Carefully lift up SD cardholder to reveal logicboard.
Nicole Wong
Membre depuis le 01/30/11
329 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 4-29, Regan Winter 2011 Membre de l'équipe Cal Poly, Team 4-29, Regan Winter 2011
CPSU-REGAN-W11S4G29
3 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,380
