Aller au contenu principal
Acer AL1714 Power Button Circuit Board
Ce dont vous avez besoin
  1. Acer AL1714 Power Button Circuit Board, Power Button Circuit Board: étape 1, image 1 de 2 Acer AL1714 Power Button Circuit Board, Power Button Circuit Board: étape 1, image 2 de 2
    • Turn the monitor facedown.
    • Unscrew the 5 screws holding the back cover on.
    • (This may require flipping the monitor over and shaking the screws loose once they're already unscrewed)
  2. Acer AL1714 Power Button Circuit Board: étape 2, image 1 de 3 Acer AL1714 Power Button Circuit Board: étape 2, image 2 de 3 Acer AL1714 Power Button Circuit Board: étape 2, image 3 de 3
    • Take the edge tool or a metal ruler and insert it into the bezel.
    • Apply pressure and push down.
    • Do the same to the right side.
    • Once the side of bezel facing you is decoupled, take the back cover and pry it loose.
  3. Acer AL1714 Power Button Circuit Board: étape 3, image 1 de 3 Acer AL1714 Power Button Circuit Board: étape 3, image 2 de 3 Acer AL1714 Power Button Circuit Board: étape 3, image 3 de 3
    • Remove the Flat Flex Cable from the Power Supply Board under the metal cover.
    • Pull the cord back and out of the way.
    • (It may be stuck down with adhesive)
  4. Acer AL1714 Power Button Circuit Board: étape 4, image 1 de 3 Acer AL1714 Power Button Circuit Board: étape 4, image 2 de 3 Acer AL1714 Power Button Circuit Board: étape 4, image 3 de 3
    • Unscrew the cord anchors for the VGA port.
    • (Use needle nose pliers if they're too tight for removal by hand)
  5. Acer AL1714 Power Button Circuit Board: étape 5, image 1 de 2 Acer AL1714 Power Button Circuit Board: étape 5, image 2 de 2
    • Turn the monitor around.
    • Unscrew the 1 screw holding the Flex Power Cable cover.
    • Lift up and remove the Flex Power Cable cover.
    • (Careful: This may be sharp)
  6. Acer AL1714 Power Button Circuit Board: étape 6, image 1 de 1
    • Unscrew the 5 screws holding the metal cage on.
  7. Acer AL1714 Power Button Circuit Board: étape 7, image 1 de 2 Acer AL1714 Power Button Circuit Board: étape 7, image 2 de 2
    • Lift up on the back of the metal cage slightly.
    • Pull the cage toward self.
    • (Must be careful to free the cover of the VGA port and power supply input)
  8. Acer AL1714 Power Button Circuit Board: étape 8, image 1 de 3 Acer AL1714 Power Button Circuit Board: étape 8, image 2 de 3 Acer AL1714 Power Button Circuit Board: étape 8, image 3 de 3
    • Lift up on the Flat Flex Cable holder tabs to release cords.
    • Lift up on the Flat Flex Cables and bend them out of the working area.
  9. Acer AL1714 Power Button Circuit Board: étape 9, image 1 de 3 Acer AL1714 Power Button Circuit Board: étape 9, image 2 de 3 Acer AL1714 Power Button Circuit Board: étape 9, image 3 de 3
    • Unplug the 4 backlight wires from their ports on the Power Supply Board.
    • (Considering their size, the best way to unplug the backlight wires is by slowly jiggling wires out of place)
  10. Acer AL1714 Power Button Circuit Board: étape 10, image 1 de 1
    • Unscrew the 5 screws holding the Power Supply Board and Video Display boards on.
  11. Acer AL1714 Power Button Circuit Board: étape 11, image 1 de 2 Acer AL1714 Power Button Circuit Board: étape 11, image 2 de 2
    • Lift up and remove the joined Power Supply Board and Video Display boards.
  12. Acer AL1714 Power Button Circuit Board: étape 12, image 1 de 3 Acer AL1714 Power Button Circuit Board: étape 12, image 2 de 3 Acer AL1714 Power Button Circuit Board: étape 12, image 3 de 3
    • Carefully detach the Power Supply and Video Display boards at their connector joint.
    • (This step is not necessary for the removal and replacement of the Power Button Circuit board)
    • (This is only a precaution so as not to bend or break the connector joint between the two boards)
  13. Acer AL1714 Power Button Circuit Board: étape 13, image 1 de 1
    • Remove the Flat Flex Cable from the Power Button Circuit Board.
  14. Acer AL1714 Power Button Circuit Board: étape 14, image 1 de 3 Acer AL1714 Power Button Circuit Board: étape 14, image 2 de 3 Acer AL1714 Power Button Circuit Board: étape 14, image 3 de 3
    • Grasp, lift, and remove the LCD Module from the front panel.
  15. Acer AL1714 Power Button Circuit Board: étape 15, image 1 de 2 Acer AL1714 Power Button Circuit Board: étape 15, image 2 de 2
    • Unscrew the 2 screws holding the Power Button Circuit Board.
  16. Acer AL1714 Power Button Circuit Board: étape 16, image 1 de 1
    • Lift and remove the Power Button Circuit Board.
3 autres ont terminé cette réparation.
Hussam Alzamzami
Membre depuis le 09/25/14
216 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 1-3, Brown Fall 2014 Membre de l'équipe USF Tampa, Team 1-3, Brown Fall 2014
USFT-BROWN-F14S1G3
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 17
Total : 1,497
