Aller au contenu principal
Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement
Ce dont vous avez besoin
  1. Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement, Lower Case: étape 1, image 1 de 1
    • Power off the machine and unplug it from the wall charger.
  2. Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement: étape 2, image 1 de 2 Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement: étape 2, image 2 de 2
    • Close the laptop and flip it over.
    • Remove the eleven 6.5 mm Phillips screws from the lower case.
  3. Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement: étape 3, image 1 de 1
    • Insert an opening pick between the lower case and chassis.
    • Pry around the entire perimeter until the lower case releases.
    • Remove the lower case.
  4. Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement: étape 4, image 1 de 1
    Outil utilisé dans cette étape :
    Anti-Static Wrist Strap
    $7.95
    J'achète
    • Optional: Put on an anti-static wrist strap. Ground yourself by connecting the metal clip at the end to any unpainted metal surface outside of the laptop.
  5. Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement, Display Assembly: étape 5, image 1 de 3 Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement, Display Assembly: étape 5, image 2 de 3 Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement, Display Assembly: étape 5, image 3 de 3
    • Disconnect the black and white antenna cables plugged into the network card on the motherboard.
    • Unscrew the four 5.5 mm Phillips screws holding the hinges of the monitor to the laptop frame.
  6. Acer Aspire 3 A315-24P-R7VH Display Assembly Replacement: étape 7, image 1 de 1
    • Once the hinges are unscrewed the display assembly will easily come off.
To reassemble you will just follow these steps in reverse order.
AlexHarpring
Membre depuis le 09/07/23
301 Réputation
3 tutoriels rédigés
Équipe
Gateway, Team 1-1, Pee Fall 2023 Membre de l'équipe Gateway, Team 1-1, Pee Fall 2023
GCC-PEE-F23S1G1
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 13
30 derniers jours : 46
Total : 226
