Introduction
The fan is the cooling component for the laptop to make sure it doesn't overheat. If you feel your laptop burning you lap or anywhere it may be sitting, it is time to replace the fan. It can even turn off if your laptop is running too hot. However it is a good thing that the fan is an easy fix to help with the cooling system. Ensure that the laptop is turned off for a couple minutes or more before to let it cool off so you can open it up and replace the fan.
Ce dont vous avez besoin
