Aller au contenu principal
Acer Aspire 3 A315-58-350L Screen Replacement
Ce dont vous avez besoin
  1. Acer Aspire 3 A315-58-350L Screen Replacement, Lower Case: étape 1, image 1 de 2 Acer Aspire 3 A315-58-350L Screen Replacement, Lower Case: étape 1, image 2 de 2
    • Remove the eleven 7 mm Phillips screws that secure the lower case.
  2. Acer Aspire 3 A315-58-350L Screen Replacement: étape 2, image 1 de 3 Acer Aspire 3 A315-58-350L Screen Replacement: étape 2, image 2 de 3 Acer Aspire 3 A315-58-350L Screen Replacement: étape 2, image 3 de 3
    • Insert an opening tool into the seam between the lower case and chassis.
    • Pry along the perimeter until the lower case releases.
    • Lift off the lower case.
  3. Acer Aspire 3 A315-58-350L Screen Replacement, Wi-Fi Card: étape 3, image 1 de 3 Acer Aspire 3 A315-58-350L Screen Replacement, Wi-Fi Card: étape 3, image 2 de 3 Acer Aspire 3 A315-58-350L Screen Replacement, Wi-Fi Card: étape 3, image 3 de 3
    • Use an opening tool to lift and disconnect the Wi-Fi card antenna cables.
    • Remove the single 2 mm Phillips screw that secures the Wi-Fi card.
    • Pull the Wi-Fi card directly out of its socket.
  4. Acer Aspire 3 A315-58-350L Screen Replacement, Screen: étape 4, image 1 de 2 Acer Aspire 3 A315-58-350L Screen Replacement, Screen: étape 4, image 2 de 2
    • Remove the six 4 mm Phillips screws that secure the hinges.
    • There are three screws securing each bracket.
  5. Acer Aspire 3 A315-58-350L Screen Replacement: étape 5, image 1 de 2 Acer Aspire 3 A315-58-350L Screen Replacement: étape 5, image 2 de 2
    • Use tweezers to grab both ends of the display connector.
    • Pull the connector directly out of its socket.
  6. Acer Aspire 3 A315-58-350L Screen Replacement: étape 6, image 1 de 3 Acer Aspire 3 A315-58-350L Screen Replacement: étape 6, image 2 de 3 Acer Aspire 3 A315-58-350L Screen Replacement: étape 6, image 3 de 3
    • Lift the laptop and gently separate the display assembly from the lower chassis.
  7. Acer Aspire 3 A315-58-350L Screen Replacement: étape 7, image 1 de 3 Acer Aspire 3 A315-58-350L Screen Replacement: étape 7, image 2 de 3 Acer Aspire 3 A315-58-350L Screen Replacement: étape 7, image 3 de 3
    • Insert an opening tool between the bezel and display
    • Pry around the entire perimeter of the screen until the bezel releases.
    • Pull the bezel away from the hinges to remove it.
  8. Acer Aspire 3 A315-58-350L Screen Replacement: étape 8, image 1 de 3 Acer Aspire 3 A315-58-350L Screen Replacement: étape 8, image 2 de 3 Acer Aspire 3 A315-58-350L Screen Replacement: étape 8, image 3 de 3
    • Remove the six 3 mm Phillips screws that secure the two hinges.
    • There are three screws that secure each hinge.
  9. Acer Aspire 3 A315-58-350L Screen Replacement: étape 9, image 1 de 3 Acer Aspire 3 A315-58-350L Screen Replacement: étape 9, image 2 de 3 Acer Aspire 3 A315-58-350L Screen Replacement: étape 9, image 3 de 3
    • Remove the two 3 mm Phillips screws on the bottom left and right corner of the screen.
    • Use an opening tool to separate the display from the display assembly.
  10. Acer Aspire 3 A315-58-350L Screen Replacement: étape 10, image 1 de 3 Acer Aspire 3 A315-58-350L Screen Replacement: étape 10, image 2 de 3 Acer Aspire 3 A315-58-350L Screen Replacement: étape 10, image 3 de 3
    • Use the tweezers to lift brass display connector hinge.
    • Pull the display connector directly out of its socket.
    • Remove the display.
Evan Sandoval
Membre depuis le 09/11/23
861 Réputation
7 tutoriels rédigés
Équipe
Austin Community College, Team 9-1, Watkins Spring 2024 Membre de l'équipe Austin Community College, Team 9-1, Watkins Spring 2024
AUSTINCC-WATKINS-S24S9G1
4 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 25
Total : 56
