Introduction
This guide will take you step by step through the process of replacing the screen on an Acer Aspire 3000. This process will involve removing the battery and keyboard as well, and will take roughly 30 minutes to complete
Ce dont vous avez besoin
Begin with the device face down.
Orient the laptop so that the battery is on the side opposite of you and the headphone ports are facing towards you.
Remove the two 4.6 mm Phillips #1 screws on the lower edge of the laptop case.
Lift the laptop to be on its edge, with the bottom of the screen in the air.
Lift the connector attached to a black cable that leads to the screen of the laptop.
Be sure to lift vertically, moving your hand slightly towards and away from you as necessary to gently separate the connectors.
Begin prying apart the two halves of the screen casing, starting at the bottom near where the cables enter the casing.
The process for separating the two halves is to take a spudger, inserting and twisting it until the tabs holding the casing together audibly pop.
Slide the spudger down the divide between the casings, twisting it whenever a tab is encountered to release it.
