Aller au contenu principal
Acer Aspire 4741G-332G32Mn Motherboard Replacement
Ce dont vous avez besoin
  1. Acer Aspire 4741G-332G32Mn Motherboard Replacement, Battery: étape 1, image 1 de 1
    • Flip the lock latch to unlock battery.
  2. Acer Aspire 4741G-332G32Mn Motherboard Replacement: étape 2, image 1 de 1
    • Slide the middle latch and remove the battery.
  3. Acer Aspire 4741G-332G32Mn Motherboard Replacement, Backplate: étape 3, image 1 de 3 Acer Aspire 4741G-332G32Mn Motherboard Replacement, Backplate: étape 3, image 2 de 3 Acer Aspire 4741G-332G32Mn Motherboard Replacement, Backplate: étape 3, image 3 de 3
    • Pry off the keyboard using the opening tool.
    • Remove the two screws that are connected to the motherboard using a Phillips #0 screwdriver.
  4. Acer Aspire 4741G-332G32Mn Motherboard Replacement: étape 4, image 1 de 1
    • Remove all 12 screws from the backplate using a Phillips #0 screwdriver.
  5. Acer Aspire 4741G-332G32Mn Motherboard Replacement: étape 5, image 1 de 1
    • Using the prying tool to remove the bottom of the laptop.
  6. Acer Aspire 4741G-332G32Mn Motherboard Replacement, Fan: étape 6, image 1 de 2 Acer Aspire 4741G-332G32Mn Motherboard Replacement, Fan: étape 6, image 2 de 2
    • Using a Phillips #0 screwdriver, remove the eight screws that hold the motherboard to the frame of the laptop.
    • Disconnect the USB port from the motherboard.
  7. Acer Aspire 4741G-332G32Mn Motherboard Replacement: étape 7, image 1 de 2 Acer Aspire 4741G-332G32Mn Motherboard Replacement: étape 7, image 2 de 2
    • Unscrew the 6 screws that hold the fan to the motherboard using the same screwdriver.
  8. Acer Aspire 4741G-332G32Mn Motherboard Replacement, Motherboard: étape 8, image 1 de 1
    • Remove the motherboard from the device.
Christopher Carstairs
Membre depuis le 03/19/19
256 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G6, Simcock Spring 2019 Membre de l'équipe UMass Dartmouth, Team S2-G6, Simcock Spring 2019
UMASSD-SIMCOCK-S19S2G6
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 16
Total : 1,137
