Aller au contenu principal
Acer Aspire 4743-6481 Keyboard Replacement
Ce dont vous avez besoin
  1. Acer Aspire 4743-6481 Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Turn over the laptop to view the underside.
  2. Acer Aspire 4743-6481 Keyboard Replacement: étape 2, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Use tweezers (or a similar tool) to slide the orange push pin. To release the battery, push it to the left.
  3. Acer Aspire 4743-6481 Keyboard Replacement: étape 3, image 1 de 1
    • You can lift the battery up and out now.
  4. Acer Aspire 4743-6481 Keyboard Replacement, Keyboard: étape 4, image 1 de 1
    • Remove the two 6.0 mm screws that secure the keyboard using a Phillips head screwdriver.
    • They can be easily identified by looking for the screws with the keyboard icon next to them.
  5. Acer Aspire 4743-6481 Keyboard Replacement: étape 5, image 1 de 2 Acer Aspire 4743-6481 Keyboard Replacement: étape 5, image 2 de 2
    • Turn the laptop over and open it.
    • Use flat edged tools to gently separate the keyboard from the laptop. It should snap off with a small amount of force.
    • Be sure to push the small tabs along the top of the keyboard, while lifting to successfully free the keyboard.
  6. Acer Aspire 4743-6481 Keyboard Replacement: étape 6, image 1 de 1
    • Gently lift away the keyboard, making sure not to damage the data cable or the connector.
    • The connection is located beneath the bottom center of the keyboard.
  7. Acer Aspire 4743-6481 Keyboard Replacement: étape 7, image 1 de 1
    • Remove piece of tape that covers the connection between the data cable and the connector.
  8. Acer Aspire 4743-6481 Keyboard Replacement: étape 8, image 1 de 1
    • Detach the data cable by flipping up the small black latch on the connector.
    • Once the latch is lifted, the keyboard should be completely free.
3 autres ont terminé cette réparation.
David Veres
Membre depuis le 02/22/17
140 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S5-G1, Lacy Spring 2017 Membre de l'équipe USF Tampa, Team S5-G1, Lacy Spring 2017
USFT-LACY-S17S5G1
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 9
30 derniers jours : 19
Total : 1,387
