Aller au contenu principal
Acer Aspire 4743-6481 Ram Card Replacement
Ce dont vous avez besoin
  1. Acer Aspire 4743-6481 Ram Card Replacement, Battery: étape 1, image 1 de 1
    • Turn over the laptop to view the underside.
  2. Acer Aspire 4743-6481 Ram Card Replacement: étape 2, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Use tweezers (or a similar tool) to slide the orange push pin. To release the battery, push it to the left.
  3. Acer Aspire 4743-6481 Ram Card Replacement: étape 3, image 1 de 1
    • You can lift the battery up and out now.
  4. Acer Aspire 4743-6481 Ram Card Replacement, RAM Card: étape 4, image 1 de 1
    • Remove three 7.0 mm screws with a Phillips head screwdriver from the back panel to gain access to the RAM cards.
  5. Acer Aspire 4743-6481 Ram Card Replacement: étape 5, image 1 de 1
    • Place the device with the battery side facing up, as shown on the picture.
    • After removing the back panel, you will see the RAM cards located to the right.
  6. Acer Aspire 4743-6481 Ram Card Replacement: étape 6, image 1 de 1
    • You should notice a silver tab on each side of the RAM card. Push each tab away at the same time to detach the card.
  7. Acer Aspire 4743-6481 Ram Card Replacement: étape 7, image 1 de 1
    • If done successfully, the RAM should pop out and you can lift it out with no effort.
AL-Moatasem
Membre depuis le 02/22/17
101 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S5-G1, Lacy Spring 2017 Membre de l'équipe USF Tampa, Team S5-G1, Lacy Spring 2017
USFT-LACY-S17S5G1
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 7
30 derniers jours : 15
Total : 719
