Aller au contenu principal
Acer Aspire 5 A515-56-347N SATA HDD Replacement
Ce dont vous avez besoin
  1. Acer Aspire 5 A515-56-347N SATA HDD Replacement, Bottom Cover: étape 1, image 1 de 2 Acer Aspire 5 A515-56-347N SATA HDD Replacement, Bottom Cover: étape 1, image 2 de 2
    • Turn the laptop off, and disconnect the power cable.
    • Flip the laptop upside down.
    • Remove the eleven 6.6 mm Phillips #0 screws from the bottom cover.
  2. Acer Aspire 5 A515-56-347N SATA HDD Replacement: étape 2, image 1 de 3 Acer Aspire 5 A515-56-347N SATA HDD Replacement: étape 2, image 2 de 3 Acer Aspire 5 A515-56-347N SATA HDD Replacement: étape 2, image 3 de 3
    • Insert a plastic opening tool into a gap between the case and the bottom cover.
    • Insert blue plastic picks into the gap between the case and the bottom cover, working around the seam.
    • The bottom cover is now loose. Pull it upwards, away from the laptop, and set it aside.
  3. Acer Aspire 5 A515-56-347N SATA HDD Replacement, Disconnecting the Battery: étape 3, image 1 de 3 Acer Aspire 5 A515-56-347N SATA HDD Replacement, Disconnecting the Battery: étape 3, image 2 de 3 Acer Aspire 5 A515-56-347N SATA HDD Replacement, Disconnecting the Battery: étape 3, image 3 de 3
    • Use a plastic spudger to loosen the black tape around the large battery connector on the motherboard.
    • Once loosened, pull back on the tape to remove it from the connector.
    • Use a plastic spudger to pull the battery connector away from the motherboard.
    • Leave the battery unplugged for the following steps.
  4. Acer Aspire 5 A515-56-347N SATA HDD Replacement: étape 4, image 1 de 2 Acer Aspire 5 A515-56-347N SATA HDD Replacement: étape 4, image 2 de 2
    • Press and hold the laptop's power button for about five seconds to discharge any remaining power in the system.
    • Do not touch any exposed components while carrying out this step or put them in contact with conductive materials.
    • Leave the battery connector unplugged and out of the way for the rest of the time the laptop is open.
  5. Acer Aspire 5 A515-56-347N SATA HDD Replacement, SATA HDD: étape 5, image 1 de 2 Acer Aspire 5 A515-56-347N SATA HDD Replacement, SATA HDD: étape 5, image 2 de 2
    • Use a plastic spudger to gently pick off the black tape securing the SATA cable to the drive caddy.
    • Rest the tape on the bottom of the drive caddy in order to secure the cable again if you ever remove the drive in the future.
  6. Acer Aspire 5 A515-56-347N SATA HDD Replacement: étape 6, image 1 de 2 Acer Aspire 5 A515-56-347N SATA HDD Replacement: étape 6, image 2 de 2
    • Using a Phillips #0 screwdriver, remove the four 4.7 mm screws that hold the drive caddy to the laptop chassis.
    • Gently pull the drive caddy out of the laptop.
  7. Acer Aspire 5 A515-56-347N SATA HDD Replacement: étape 7, image 1 de 2 Acer Aspire 5 A515-56-347N SATA HDD Replacement: étape 7, image 2 de 2
    • Place the SATA drive into the newly-removed drive caddy.
    • Make sure you insert the drive into the caddy exactly as displayed in the image. The SATA port on the drive must fit between the two screw posts on the drive caddy.
    • Screw the SATA drive into the caddy.
    • In most cases, your new drive will have come with the appropriate mounting screws.
  8. Acer Aspire 5 A515-56-347N SATA HDD Replacement: étape 8, image 1 de 2 Acer Aspire 5 A515-56-347N SATA HDD Replacement: étape 8, image 2 de 2
    • Plug the free SATA cable from the laptop into the SATA connector on your newly-installed drive.
    • Insert the drive caddy back into its space on the laptop, and follow steps 6 through 1 in reverse order to reassemble your device.
Ethan Griffin
Membre depuis le 02/21/24
193 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 27
Total : 234
