Aller au contenu principal
Acer Aspire 5100 Track Pad Replacement
Ce dont vous avez besoin
  1. Acer Aspire 5100 Track Pad Replacement, Keyboard: étape 1, image 1 de 2 Acer Aspire 5100 Track Pad Replacement, Keyboard: étape 1, image 2 de 2
    • Open and push the screen back all the way until it is horizontal with the rest of the laptop.
    • Use an opening tool to remove the panel above the keyboard that has the power button on it.
    • After you have released the tabs, lift up the panel.
  2. Acer Aspire 5100 Track Pad Replacement: étape 2, image 1 de 3 Acer Aspire 5100 Track Pad Replacement: étape 2, image 2 de 3 Acer Aspire 5100 Track Pad Replacement: étape 2, image 3 de 3
    • Under the panel, remove the two screws that connect the keyboard to the laptop.
    • One screw is located above the F5 button, and the other one is located above the F10 button.
    • Potential for device damage: Lift up the keyboard CAREFULLY because there is a ribbon that connects the keyboard to the motherboard.
  3. Acer Aspire 5100 Track Pad Replacement: étape 3, image 1 de 1
    • Release the catch on the ribbon socket by sliding the two tabs toward the ribbon.
    • Pull the ribbon under the keyboard to detach it from the motherboard.
    • Remove the keyboard.
    do not pull on ribbon it will only break the cable. instead use tool to detach from mother board. i broke mine by pulling ribbon.
    steve foss - Réponse
    useless guide, there are a lot of screws that lock the cover on the laptop and you have never showed them
    Valerio Vischio - Réponse
    You do not need to remove the whole cover, in order to replace the keyboard.
    The description for this job is right.
    The switch plate cover just pops off.
    Screws revealed, secure the keyboard.
    Unclip the ribbon cable.
    Job done
    Richard -
  4. Acer Aspire 5100 Track Pad Replacement, Track Pad: étape 4, image 1 de 1
    • Remove the nine screws from the back edges of the laptop.
  5. Acer Aspire 5100 Track Pad Replacement: étape 5, image 1 de 3 Acer Aspire 5100 Track Pad Replacement: étape 5, image 2 de 3 Acer Aspire 5100 Track Pad Replacement: étape 5, image 3 de 3
    • Open the lid of the laptop and locate the cover that surrounds the keyboard and track pad.
    • Use the spudger to pry open the sides of this cover.
    • DO NOT lift cover off after detaching it because the track pad is connected to the motherboard.
  6. Acer Aspire 5100 Track Pad Replacement: étape 6, image 1 de 2 Acer Aspire 5100 Track Pad Replacement: étape 6, image 2 de 2
    • Slightly lift up the cover to see the ribbon connection.
    • Release the catch by sliding the two lugs toward the ribbon, then pull the ribbon to detach it from the motherboard.
    • Lift up the cover from the laptop.
  7. Acer Aspire 5100 Track Pad Replacement: étape 7, image 1 de 1
    • On the cover that was removed, flip it around and locate where the back of the track pad is.
    • Remove the three screws located at the corners.
    • Lift up the bracket that you just unscrewed and remove track pad.
2 autres ont terminé cette réparation.
Brad Rollinson
Membre depuis le 09/29/10
1 113 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 14-39, Forte Fall 2010 Membre de l'équipe Cal Poly, Team 14-39, Forte Fall 2010
CPSU-FORTE-F10S14G39
5 membres
10 tutoriels rédigés
3 commentaires
You left out about 10 screws & assemblies that have to ALSO be removed to release the cover that surrounds the keyboard and track pad.
Jack Hickey - Réponse
You have to remove the video cable, wifi cables and LCD before you try to remove the touchpad/upper cover. You must also remove two screws from the bottom labeled 10x. In other words, you should remove the parts I mentioned before attempting to complete steps 5 to 7.
Nelson Mata - Réponse
The Fan must also be removed before removing the touchpad/upper cover.
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 9,381
