Aller au contenu principal
Acer Aspire 5334-2581 Keyboard Replacement
Ce dont vous avez besoin
  1. Acer Aspire 5334-2581 Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Please make sure your device is unplugged . Turn it over slowly, and place it on a flat surface.
  2. Acer Aspire 5334-2581 Keyboard Replacement: étape 2, image 1 de 1
    • This latch holds your battery in place, it should always be locked. Make sure to unlock this piece.
    • Do not break this latch, otherwise your battery will not hold in place.
  3. Acer Aspire 5334-2581 Keyboard Replacement: étape 3, image 1 de 1
    • Locate the eject latch and push it so the battery can come out.
    • The battery will lift up once you have pushed the latch.
    • You DO NOT need to adjust the latch when replacing the new battery, because it just snaps in place.
  4. Acer Aspire 5334-2581 Keyboard Replacement: étape 4, image 1 de 1
    • Lift the battery up, and it should just come right off. You should see the label with the part number.
  5. Acer Aspire 5334-2581 Keyboard Replacement, Keyboard: étape 5, image 1 de 3 Acer Aspire 5334-2581 Keyboard Replacement, Keyboard: étape 5, image 2 de 3 Acer Aspire 5334-2581 Keyboard Replacement, Keyboard: étape 5, image 3 de 3
    • The keyboard is held underneath a plastic cover. remove this cover with a spudger.
    • Using a spudger, apply it underneath the keyboard and lift it up.
  6. Acer Aspire 5334-2581 Keyboard Replacement: étape 6, image 1 de 2 Acer Aspire 5334-2581 Keyboard Replacement: étape 6, image 2 de 2
    • Disconnect the keyboard flex cable, and now you are ready to install a new keyboard.
    • Take extra care, and try not to break the the latch that holds the cable in place.
gilson teixeira
Membre depuis le 10/20/16
334 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-2, Catania Fall 2016 Membre de l'équipe UMass Dartmouth, Team 1-2, Catania Fall 2016
UMASSD-CATANIA-F16S1G2
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 10
Total : 702
