Aller au contenu principal
Acer Aspire 5534-1146 Battery Replacement
Ce dont vous avez besoin
  1. Acer Aspire 5534-1146 Battery Replacement, Battery: étape 1, image 1 de 1
    • Make sure your device is unplugged from the power source . Gently turn it over, and lay it on a flat on its face.
  2. Acer Aspire 5534-1146 Battery Replacement: étape 2, image 1 de 1
    • This latch locks your battery in place, it should always be locked with the exception of replacement. Slide it horizontally to the unlock position.
    • Do not break this latch, otherwise your battery will not hold in place.
  3. Acer Aspire 5534-1146 Battery Replacement: étape 3, image 1 de 1
    • Locate the latch that ejects the battery (top right corner) and push it to the left, so the battery can come out.
    • The battery will pull out once the latch is positioned to the left.
    • You DO NOT need to push on the ejecting latch when replacing the new battery, it will snap into place itself.
  4. Acer Aspire 5534-1146 Battery Replacement: étape 4, image 1 de 1
    • Push the battery forward and it will slide out, it should come out with ease. There should be a label with the part number.
Eric Weaver
Membre depuis le 10/02/18
186 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 11
Total : 461
