Aller au contenu principal
Acer Aspire 5534-1146 Screen Replacement
Ce dont vous avez besoin
  1. Acer Aspire 5534-1146 Screen Replacement, Screen: étape 1, image 1 de 2 Acer Aspire 5534-1146 Screen Replacement, Screen: étape 1, image 2 de 2
    • Use the blue spudger to remove the 4 rubber supports from each corner of the screen.
    • After use a PH0 screw bit to remove the corresponding screws underneath.
  2. Acer Aspire 5534-1146 Screen Replacement: étape 2, image 1 de 1
    • Use a plastic opening tool to carefully release the plastic clips that hold the plastic frame to the back cover.
    • Be careful while handling the bottom, there are cable connections and you don't want to damage them.
  3. Acer Aspire 5534-1146 Screen Replacement: étape 3, image 1 de 2 Acer Aspire 5534-1146 Screen Replacement: étape 3, image 2 de 2
    • Gently disconnect the camera cable.
  4. Acer Aspire 5534-1146 Screen Replacement: étape 4, image 1 de 1
    • Remove the 4 screws in the corners underneath the plastic frame that was removed. Screen should then be able to come of the frame.
  5. Acer Aspire 5534-1146 Screen Replacement: étape 5, image 1 de 1
    • Take the screen lay it face down on top of the keyboard.
    • Unplug the cable that is connected to the video card.
    • This cable may be taped down to the back of the screen, if necessary lift the tape gently.
  6. Acer Aspire 5534-1146 Screen Replacement: étape 6, image 1 de 1
    • Remove the tape, and unplug the display cable on the back of the screen.
    • Pull the tape off of the cable from the back of the screen, and now the screen should be free to come off. You are now ready to install a new one.
Trysten buckley
Membre depuis le 10/09/18
337 Réputation
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 9
Total : 248
