Introduction
Use this guide to remove the WLAN module from your device.
Ce dont vous avez besoin
Étape 1 Prepare Acer Aspire 5740-5780 for Disassembly
Attention : les étapes 1 à 4 sont issues d'un tutoriel marqué comme en cours.
Turn the laptop off and remove the power cord.
Put grounding strap on one of your wrists and attach the other end to a large metal object (recommended method).
If you don't have a grounding strap an alternative approach is to touch a metal object that is either large or connected to the earth. Then avoid doing things that would accumulate static electricity on your body.
Unscrew the 2 captive screws and 3 M2.5 x L8 screws holding back cover in place.
