Aller au contenu principal
Acer Aspire 5741-5698 WIFI Chipset Replacement
Ce dont vous avez besoin
  1. Acer Aspire 5741-5698 WIFI Chipset Replacement, WIFI Chipset: étape 1, image 1 de 3 Acer Aspire 5741-5698 WIFI Chipset Replacement, WIFI Chipset: étape 1, image 2 de 3 Acer Aspire 5741-5698 WIFI Chipset Replacement, WIFI Chipset: étape 1, image 3 de 3
    • Begin on the back side of your laptop, locate these two screws then remove them with the JIS #0 driver bit.
  2. Acer Aspire 5741-5698 WIFI Chipset Replacement: étape 2, image 1 de 2 Acer Aspire 5741-5698 WIFI Chipset Replacement: étape 2, image 2 de 2
    • Once screws are removed you can pry up the panel to reveal some of your computers components.
  3. Acer Aspire 5741-5698 WIFI Chipset Replacement: étape 3, image 1 de 1
    • Locate your computers WIFI chip; it will have black and white wires attached to it.
  4. Acer Aspire 5741-5698 WIFI Chipset Replacement: étape 4, image 1 de 3 Acer Aspire 5741-5698 WIFI Chipset Replacement: étape 4, image 2 de 3 Acer Aspire 5741-5698 WIFI Chipset Replacement: étape 4, image 3 de 3
    • Using your fingers or a spudger, remove the black and white cables from the chip, at the connector.
  5. Acer Aspire 5741-5698 WIFI Chipset Replacement: étape 5, image 1 de 2 Acer Aspire 5741-5698 WIFI Chipset Replacement: étape 5, image 2 de 2
    • Using the same JIS#0 screw driver remove the single small 1/4 inch long screw.
  6. Acer Aspire 5741-5698 WIFI Chipset Replacement: étape 6, image 1 de 3 Acer Aspire 5741-5698 WIFI Chipset Replacement: étape 6, image 2 de 3 Acer Aspire 5741-5698 WIFI Chipset Replacement: étape 6, image 3 de 3
    • Now that the chip is released just gently remove it from its connector seat.
Alex Imbery
Membre depuis le 01/24/19
133 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S18-G6, White Winter 2019 Membre de l'équipe Cal Poly, Team S18-G6, White Winter 2019
CPSU-WHITE-W19S18G6
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 18
Total : 588
