Aller au contenu principal
Acer Aspire 5742 RAM Replacement
Ce dont vous avez besoin
  1. Acer Aspire 5742 RAM Replacement, Battery: étape 1, image 1 de 3 Acer Aspire 5742 RAM Replacement, Battery: étape 1, image 2 de 3 Acer Aspire 5742 RAM Replacement, Battery: étape 1, image 3 de 3
    • Move the battery catch to the "unlocked" position.
    • Pull back the second spring-loaded battery catch until the battery pops up.
    • Remove the battery.
  2. Acer Aspire 5742 RAM Replacement, Cover Panel: étape 2, image 1 de 3 Acer Aspire 5742 RAM Replacement, Cover Panel: étape 2, image 2 de 3 Acer Aspire 5742 RAM Replacement, Cover Panel: étape 2, image 3 de 3
    • Turn the notebook around to face you.
    • There are two Phillips #00 screws securing the cover panel to the rest of the notebook. Remove these screws.
  3. Acer Aspire 5742 RAM Replacement: étape 3, image 1 de 3 Acer Aspire 5742 RAM Replacement: étape 3, image 2 de 3 Acer Aspire 5742 RAM Replacement: étape 3, image 3 de 3
    • Use a spudger to release the panel from the plastic retaining clips keeping it in place.
    • Do not apply too much force, or you may break the clips.
    • Remove the panel and set it aside.
  4. Acer Aspire 5742 RAM Replacement, RAM: étape 4, image 1 de 3 Acer Aspire 5742 RAM Replacement, RAM: étape 4, image 2 de 3 Acer Aspire 5742 RAM Replacement, RAM: étape 4, image 3 de 3
    • The RAM is protected by a transparent cellophane cover.
    • Lift this cover away from the RAM. It will not come free from the RAM.
    • You may wish to use some Scotch tape to hold the cover in place while you work.
  5. Acer Aspire 5742 RAM Replacement: étape 5, image 1 de 2 Acer Aspire 5742 RAM Replacement: étape 5, image 2 de 2
    • Pull back the retaining clips either side of the RAM.
    • It will spring up, ready to be removed.
  6. Acer Aspire 5742 RAM Replacement: étape 6, image 1 de 3 Acer Aspire 5742 RAM Replacement: étape 6, image 2 de 3 Acer Aspire 5742 RAM Replacement: étape 6, image 3 de 3
    • Hold on to opposite edges of the RAM chip and gently pull it diagonally upwards to remove it from the computer.
    • Repeat steps 5 and 6 for the second RAM chip if necessary.
  7. Acer Aspire 5742 RAM Replacement: étape 7, image 1 de 2 Acer Aspire 5742 RAM Replacement: étape 7, image 2 de 2
    • When reinserting RAM, push it diagonally downwards until almost all of the gold connector strip is inside the socket.
    • Push gently down on the RAM until the retaining clips click back over it.
5 autres ont terminé cette réparation.
Skylar MacDonald
Membre depuis le 12/04/11
1 964 Réputation
5 tutoriels rédigés
2 commentaires
note to add: it only supports 8gb (2x4gb) max
SquinteyedSniper - Réponse
Hi, not sure if this is the right place to post this troubleshooting request.
I’ve re-seated the original 4GB memory and added a further 4GB into the additional slot on my acer Aspire 5742 laptop. When I turn it on, the machine shows the initial ACER splash screen with the ‘Press <F2> to enter Setup.’ message in the bottom left-hand corner and the hard drive briefly whirls before the laptop powers down. It then powers back up and continually loops this cycle until I remove the power sources (mains and battery). When I press <F2>, I get 4 (four) short, quick beeps - which I think is telling me to re-seat the RAM. I have re-seated the RAM a handful of times without any progress in the reboot.
Any pointers please as to where I am going wrong or what to try next?
Stuart Adams - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 34
Total : 10,565
