Aller au contenu principal
Acer Aspire 7736Z-4809 CPU Fan Replacement
Ce dont vous avez besoin
  1. Acer Aspire 7736Z-4809 CPU Fan Replacement, Acer Aspire 7736Z-4809 Repair Preparation: étape 1, image 1 de 1
    • Unplug and power off the laptop.
    • If the battery is still connected to the laptop, remove the battery.
  2. Acer Aspire 7736Z-4809 CPU Fan Replacement: étape 2, image 1 de 1
    • Flip over the laptop so that the back panel of the laptop is facing up.
  3. Acer Aspire 7736Z-4809 CPU Fan Replacement, Back Panel: étape 3, image 1 de 2 Acer Aspire 7736Z-4809 CPU Fan Replacement, Back Panel: étape 3, image 2 de 2
    • Use the Phillips #1 screwdriver to remove the eight 6.5 mm Phillips #1 screws.
    • Only the four screws in the center are removable, the four along the edges are held in by rivets but can be loosened.
  4. Acer Aspire 7736Z-4809 CPU Fan Replacement: étape 4, image 1 de 3 Acer Aspire 7736Z-4809 CPU Fan Replacement: étape 4, image 2 de 3 Acer Aspire 7736Z-4809 CPU Fan Replacement: étape 4, image 3 de 3
    • Remove the back panel of the laptop.
  5. Acer Aspire 7736Z-4809 CPU Fan Replacement: étape 5, image 1 de 1
    • Connect a grounding cord to a metal interface on the laptop.
    • Ground the laptop to prevent static electricity from damaging the electrical components inside the laptop.
  6. Acer Aspire 7736Z-4809 CPU Fan Replacement, CPU Fan: étape 6, image 1 de 3 Acer Aspire 7736Z-4809 CPU Fan Replacement, CPU Fan: étape 6, image 2 de 3 Acer Aspire 7736Z-4809 CPU Fan Replacement, CPU Fan: étape 6, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Use tweezers to remove the fan cable from its slot.
    • The cables consist of red, black, and yellow wires.
  7. Acer Aspire 7736Z-4809 CPU Fan Replacement: étape 7, image 1 de 2 Acer Aspire 7736Z-4809 CPU Fan Replacement: étape 7, image 2 de 2
    • Use the Phillips #1 screwdriver to unscrew the four Phillips #1 screws that connect the cooling fan from the panel.
    • These screws are held in the unit via springs. You cannot remove them. They can only be loosened.
  8. Acer Aspire 7736Z-4809 CPU Fan Replacement: étape 8, image 1 de 3 Acer Aspire 7736Z-4809 CPU Fan Replacement: étape 8, image 2 de 3 Acer Aspire 7736Z-4809 CPU Fan Replacement: étape 8, image 3 de 3
    • Carefully remove the cooling fan from the motherboard.
    • Slightly lift up the fan, gradually slide it towards you and then fully remove it from the case.
  9. Acer Aspire 7736Z-4809 CPU Fan Replacement: étape 9, image 1 de 1
    • Install the modified or new cooling fan.
2 autres ont terminé cette réparation.
Pnithan Jantarakolica
Membre depuis le 09/22/16
1 153 Réputation
10 tutoriels rédigés
Équipe
UC Davis, Team 2-4, Oliver Fall 2016 Membre de l'équipe UC Davis, Team 2-4, Oliver Fall 2016
UCD-OLIVER-F16S2G4
5 membres
Un commentaire
You’ll need some thermal compound when reinstalling for the heat syncs under the copper tube.
Minks - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 9
Total : 791
