Aller au contenu principal
Acer Aspire 7736Z-4809 Hard Drive Replacement
Ce dont vous avez besoin
  1. Acer Aspire 7736Z-4809 Hard Drive Replacement, Acer Aspire 7736Z-4809 Repair Preparation: étape 1, image 1 de 1
    • Unplug and power off the laptop.
    • If the battery is still connected to the laptop, remove the battery.
  2. Acer Aspire 7736Z-4809 Hard Drive Replacement: étape 2, image 1 de 1
    • Flip over the laptop so that the back panel of the laptop is facing up.
  3. Acer Aspire 7736Z-4809 Hard Drive Replacement, Back Panel: étape 3, image 1 de 2 Acer Aspire 7736Z-4809 Hard Drive Replacement, Back Panel: étape 3, image 2 de 2
    • Use the Phillips #1 screwdriver to remove the eight 6.5 mm Phillips #1 screws.
    • Only the four screws in the center are removable, the four along the edges are held in by rivets but can be loosened.
  4. Acer Aspire 7736Z-4809 Hard Drive Replacement: étape 4, image 1 de 3 Acer Aspire 7736Z-4809 Hard Drive Replacement: étape 4, image 2 de 3 Acer Aspire 7736Z-4809 Hard Drive Replacement: étape 4, image 3 de 3
    • Remove the back panel of the laptop.
  5. Acer Aspire 7736Z-4809 Hard Drive Replacement: étape 5, image 1 de 1
    • Connect a grounding cord to a metal interface on the laptop.
    • Ground the laptop to prevent static electricity from damaging the electrical components inside the laptop.
  6. Acer Aspire 7736Z-4809 Hard Drive Replacement, Hard Drive: étape 6, image 1 de 2 Acer Aspire 7736Z-4809 Hard Drive Replacement, Hard Drive: étape 6, image 2 de 2
    • Use the Phillips #1 screwdriver to remove the 3.5mm Phillips #1 screw.
  7. Acer Aspire 7736Z-4809 Hard Drive Replacement: étape 7, image 1 de 2 Acer Aspire 7736Z-4809 Hard Drive Replacement: étape 7, image 2 de 2
    • Slide the bracket towards you to release it from the frame.
  8. Acer Aspire 7736Z-4809 Hard Drive Replacement: étape 8, image 1 de 3 Acer Aspire 7736Z-4809 Hard Drive Replacement: étape 8, image 2 de 3 Acer Aspire 7736Z-4809 Hard Drive Replacement: étape 8, image 3 de 3
    • Use the black tab to pull the hard drive up and out of the laptop.
  9. Acer Aspire 7736Z-4809 Hard Drive Replacement: étape 9, image 1 de 2 Acer Aspire 7736Z-4809 Hard Drive Replacement: étape 9, image 2 de 2
    • Use the Phillips #1 screwdriver to remove the four 3.5 Phillips #1 screws.
  10. Acer Aspire 7736Z-4809 Hard Drive Replacement: étape 10, image 1 de 1
    • Remove the hard drive from the bracket and install the new hard drive.
Pnithan Jantarakolica
Membre depuis le 09/22/16
1 153 Réputation
10 tutoriels rédigés
Équipe
UC Davis, Team 2-4, Oliver Fall 2016 Membre de l'équipe UC Davis, Team 2-4, Oliver Fall 2016
UCD-OLIVER-F16S2G4
5 membres
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 12
Total : 1,067
