Aller au contenu principal
Acer Aspire 7736Z-4809 RAM Replacement
Ce dont vous avez besoin
  1. Acer Aspire 7736Z-4809 RAM Replacement, Back Panel: étape 1, image 1 de 2 Acer Aspire 7736Z-4809 RAM Replacement, Back Panel: étape 1, image 2 de 2
    • Use the Phillips #1 screwdriver to remove the eight 6.5 mm Phillips #1 screws.
    • Only the four screws in the center are removable, the four along the edges are held in by rivets but can be loosened.
  2. Acer Aspire 7736Z-4809 RAM Replacement: étape 2, image 1 de 3 Acer Aspire 7736Z-4809 RAM Replacement: étape 2, image 2 de 3 Acer Aspire 7736Z-4809 RAM Replacement: étape 2, image 3 de 3
    • Remove the back panel of the laptop.
  3. Acer Aspire 7736Z-4809 RAM Replacement: étape 3, image 1 de 1
    • Connect a grounding cord to a metal interface on the laptop.
    • Ground the laptop to prevent static electricity from damaging the electrical components inside the laptop.
  4. Acer Aspire 7736Z-4809 RAM Replacement, RAM: étape 4, image 1 de 3 Acer Aspire 7736Z-4809 RAM Replacement, RAM: étape 4, image 2 de 3 Acer Aspire 7736Z-4809 RAM Replacement, RAM: étape 4, image 3 de 3
    • Release the tabs on the RAM by bending the tabs away from the RAM.
    • The RAM will rise upwards at an angle.
  5. Acer Aspire 7736Z-4809 RAM Replacement: étape 5, image 1 de 2 Acer Aspire 7736Z-4809 RAM Replacement: étape 5, image 2 de 2
    • Pull the RAM out of the slot.
    • If you are replacing both sticks of RAM, repeat the previous step for removing the RAM.
Pnithan Jantarakolica
Membre depuis le 09/22/16
1 153 Réputation
10 tutoriels rédigés
Équipe
UC Davis, Team 2-4, Oliver Fall 2016 Membre de l'équipe UC Davis, Team 2-4, Oliver Fall 2016
UCD-OLIVER-F16S2G4
5 membres
2 commentaires
“supports the DDR2 667MHz memory,240-pin soDIMM RAM “
It’s a laptop and what you are holding is a 200-pin soDIMM RAM module.
BaronDRS - Réponse
Not only is it 200-pin soDIMM module instead of a 240-pin soDIMM module, it's a pc2-6400 (800MHz) and not a pc2-5300 (667MHz).
1videopirate - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 10
Total : 623
