Aller au contenu principal
Acer Aspire E1-531-2438 Speakers Replacement
Ce dont vous avez besoin
  1. Acer Aspire E1-531-2438 Speakers Replacement, Battery: étape 1, image 1 de 2 Acer Aspire E1-531-2438 Speakers Replacement, Battery: étape 1, image 2 de 2
    • Unplug and power down the device before removing the battery.
    • Turn the device over so the back side is facing up.
    • Using a spudger, slide the orange latch to the right. This will release the battery, which should pop up from the device.
    • Use two hands tilt the side of the battery closest to the orange latch upward as shown in the images.
  2. Acer Aspire E1-531-2438 Speakers Replacement: étape 2, image 1 de 1
    • Tilt the side of the battery closest to the orange latch upward.
    • Lift the battery up and out of the device.
  3. Acer Aspire E1-531-2438 Speakers Replacement, Hard Drive: étape 3, image 1 de 2 Acer Aspire E1-531-2438 Speakers Replacement, Hard Drive: étape 3, image 2 de 2
    • Using a Phillips #0 screwdriver, remove the two 9mm screws on the access panel.
  4. Acer Aspire E1-531-2438 Speakers Replacement: étape 4, image 1 de 3 Acer Aspire E1-531-2438 Speakers Replacement: étape 4, image 2 de 3 Acer Aspire E1-531-2438 Speakers Replacement: étape 4, image 3 de 3
    • Using the indentation, pry open the access panel with your fingers or a spudger.
    • Remove the access panel to expose the hard drive, WiFi chip, and RAM modules.
  5. Acer Aspire E1-531-2438 Speakers Replacement: étape 5, image 1 de 3 Acer Aspire E1-531-2438 Speakers Replacement: étape 5, image 2 de 3 Acer Aspire E1-531-2438 Speakers Replacement: étape 5, image 3 de 3
    • Grip the plastic tab on the hard drive, then pull to the left to unplug the drive from its socket.
    • Once free from the socket, lift the hard drive up and out of the device.
  6. Acer Aspire E1-531-2438 Speakers Replacement, Speakers: étape 6, image 1 de 3 Acer Aspire E1-531-2438 Speakers Replacement, Speakers: étape 6, image 2 de 3 Acer Aspire E1-531-2438 Speakers Replacement, Speakers: étape 6, image 3 de 3
    • Using a Phillips #0 screwdriver, remove all of the following screws:
    • Fifteen 9mm size screws
    • One 6mm screw
    • Three 3.5mm screws
  7. Acer Aspire E1-531-2438 Speakers Replacement: étape 7, image 1 de 3 Acer Aspire E1-531-2438 Speakers Replacement: étape 7, image 2 de 3 Acer Aspire E1-531-2438 Speakers Replacement: étape 7, image 3 de 3
    • Remove the optical drive by sliding it out of its slot on the side of the laptop.
  8. Acer Aspire E1-531-2438 Speakers Replacement: étape 8, image 1 de 2 Acer Aspire E1-531-2438 Speakers Replacement: étape 8, image 2 de 2
    • Using a plastic opening tool, pry along the seam running the perimeter of the laptop to separate the bottom case from the palmrest assembly.
    • Flip the device over and open the laptop so that the keyboard is visible.
    • Lift up the palmrest assembly just far enough to access the connectors underneath.
  9. Acer Aspire E1-531-2438 Speakers Replacement: étape 9, image 1 de 2 Acer Aspire E1-531-2438 Speakers Replacement: étape 9, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Using a pair of tweezers, disconnect the small white ribbon cable from the connector near the left side of the device.
    • Disconnect the large black ribbon cable near the middle of the device. Gently pull on the cable away from you.
  10. Acer Aspire E1-531-2438 Speakers Replacement: étape 10, image 1 de 1
    • Lift and remove the palmrest assembly and the attached keyboard.
  11. Acer Aspire E1-531-2438 Speakers Replacement: étape 11, image 1 de 3 Acer Aspire E1-531-2438 Speakers Replacement: étape 11, image 2 de 3 Acer Aspire E1-531-2438 Speakers Replacement: étape 11, image 3 de 3
    • Using a spudger, disconnect the connector for the left speaker.
    • Disconnect the right speaker connector in the same manner.
  12. Acer Aspire E1-531-2438 Speakers Replacement: étape 12, image 1 de 2 Acer Aspire E1-531-2438 Speakers Replacement: étape 12, image 2 de 2
    • Using a Phillips #0 screwdriver, remove the four 3mm screws to release the left and right speakers.
  13. Acer Aspire E1-531-2438 Speakers Replacement: étape 13, image 1 de 2 Acer Aspire E1-531-2438 Speakers Replacement: étape 13, image 2 de 2
    • Lift and remove the left and right speakers.
Jakob Rinkus
Membre depuis le 03/21/19
965 Réputation
7 tutoriels rédigés
Équipe
UMass Dartmouth, Team S8-G2, Bailey Spring 2019 Membre de l'équipe UMass Dartmouth, Team S8-G2, Bailey Spring 2019
UMASSD-BAILEY-S19S8G2
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 10
30 derniers jours : 20
Total : 1,108
