Introduction
If your Acer Aspire E1-572-6829 is having trouble connecting to Wi-Fi, the Wi-Fi card may need replacement. First read through our troubleshooting page and make sure the Wi-Fi is turned on and try updating your WiFi drivers. If neither of those work, then follow these steps to replace the Wi-Fi card.
The Wi-Fi card is how your device connects to the Internet, so if it is broken, that will cause problems with your Acer Aspire E1-572-6829 connecting to the Internet.
Make sure that your device is powered off and the charger is unplugged before beginning the steps in this guide.
Ce dont vous avez besoin
Flip the laptop over so that you are facing the back panel.
Locate the battery lock switch below the battery.
Use a Phillips #0 screwdriver to remove the seventeen 8 mm screws that secure the back panel.
Use a plastic spudger to pry open the lower back panel from its top edge.
Lift the panel up and out to remove it.
Detach the two cables connected to the Wi-Fi card. Gently pull them off using a plastic pry tool or your fingers.
