Aller au contenu principal
Acer Aspire E5-571 CPU Fan Replacement
Ce dont vous avez besoin
  1. Acer Aspire E5-571 CPU Fan Replacement, Battery: étape 1, image 1 de 1
    • Make sure the laptop is shut down.
    • Flip the laptop upside down. Rotate it so the battery faces you.
  2. Acer Aspire E5-571 CPU Fan Replacement: étape 2, image 1 de 1
    • Place the pointed end of a spudger into the battery lock. Slide the battery lock to the left using the spudger. A "click" sound will accompany the release of the battery.
  3. Acer Aspire E5-571 CPU Fan Replacement: étape 3, image 1 de 1
    • Pull the battery towards you to remove it from the laptop.
  4. Acer Aspire E5-571 CPU Fan Replacement, Keyboard: étape 4, image 1 de 1
    • Remove all eighteen 8 mm screws with a Phillips #0 screwdriver.
  5. Acer Aspire E5-571 CPU Fan Replacement: étape 5, image 1 de 3 Acer Aspire E5-571 CPU Fan Replacement: étape 5, image 2 de 3 Acer Aspire E5-571 CPU Fan Replacement: étape 5, image 3 de 3
    • Carefully pry apart the clips holding the keyboard in place by moving a metal spudger along the seam.
    • Be careful not to break the plastic clips. Do not remove the keyboard until told to do so.
  6. Acer Aspire E5-571 CPU Fan Replacement: étape 6, image 1 de 2 Acer Aspire E5-571 CPU Fan Replacement: étape 6, image 2 de 2
    • Carefully flip up the white hinge. Then, detach the three ZIF ribbons connected to the motherboard.
    • Remove the panel with the keyboard and the touchpad.
  7. Acer Aspire E5-571 CPU Fan Replacement, WiFi: étape 7, image 1 de 1
    • Locate the WiFi card on the motherboard.
  8. Acer Aspire E5-571 CPU Fan Replacement: étape 8, image 1 de 2 Acer Aspire E5-571 CPU Fan Replacement: étape 8, image 2 de 2
    • Locate the two antenna cables shown.
    • Using a plastic opening tool, remove both antenna cables from the WiFi card by gently prying them up.
    • Black on left. White on right.
  9. Acer Aspire E5-571 CPU Fan Replacement: étape 9, image 1 de 3 Acer Aspire E5-571 CPU Fan Replacement: étape 9, image 2 de 3 Acer Aspire E5-571 CPU Fan Replacement: étape 9, image 3 de 3
    • Remove this 3 mm Phillips #0 screw and the WiFi card should pop up.
    • Make sure antenna cables are removed before removing the screw.
    • Gently lift WiFi card off of the motherboard.
  10. Acer Aspire E5-571 CPU Fan Replacement, CPU Fan: étape 10, image 1 de 1
    • Locate the CPU Fan in the case right above the motherboard.
  11. Acer Aspire E5-571 CPU Fan Replacement: étape 11, image 1 de 1
    • Detach the power cable by carefully pulling on it, it will come off easily.
  12. Acer Aspire E5-571 CPU Fan Replacement: étape 12, image 1 de 1
    • Remove both of these 6 mm Phillips #1 screws which hold the fan onto the case.
    • Now carefully lift the fan straight up and out of its place in the case.
    • The fan should easily come right out with no trouble.
4 autres ont terminé cette réparation.
daniel sawyer
Membre depuis le 08/23/15
2 566 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 4-2, Meier Fall 2015 Membre de l'équipe USF Tampa, Team 4-2, Meier Fall 2015
USFT-MEIER-F15S4G2
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 20
Total : 4,313
