Aller au contenu principal
Acer Aspire E5-571 Keyboard Replacement
Ce dont vous avez besoin
  1. Acer Aspire E5-571 Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Make sure the laptop is shut down.
    • Flip the laptop upside down. Rotate it so the battery faces you.
  2. Acer Aspire E5-571 Keyboard Replacement: étape 2, image 1 de 1
    • Place the pointed end of a spudger into the battery lock. Slide the battery lock to the left using the spudger. A "click" sound will accompany the release of the battery.
  3. Acer Aspire E5-571 Keyboard Replacement: étape 3, image 1 de 1
    • Pull the battery towards you to remove it from the laptop.
  4. Acer Aspire E5-571 Keyboard Replacement, Keyboard: étape 4, image 1 de 1
    • Remove all eighteen 8 mm screws with a Phillips #0 screwdriver.
  5. Acer Aspire E5-571 Keyboard Replacement: étape 5, image 1 de 3 Acer Aspire E5-571 Keyboard Replacement: étape 5, image 2 de 3 Acer Aspire E5-571 Keyboard Replacement: étape 5, image 3 de 3
    • Carefully pry apart the clips holding the keyboard in place by moving a metal spudger along the seam.
    • Be careful not to break the plastic clips. Do not remove the keyboard until told to do so.
  6. Acer Aspire E5-571 Keyboard Replacement: étape 6, image 1 de 2 Acer Aspire E5-571 Keyboard Replacement: étape 6, image 2 de 2
    • Carefully flip up the white hinge. Then, detach the three ZIF ribbons connected to the motherboard.
    • Remove the panel with the keyboard and the touchpad.
9 autres ont terminé cette réparation.
daniel sawyer
Membre depuis le 08/23/15
2 566 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 4-2, Meier Fall 2015 Membre de l'équipe USF Tampa, Team 4-2, Meier Fall 2015
USFT-MEIER-F15S4G2
3 membres
5 tutoriels rédigés
4 commentaires
keyboard cable is a b$%*h
shrs - Réponse
can you explain how to remove the keyboard and attach the new one to the whole top
christhesoccerkid - Réponse
keyboard cable is indeed a b$%*h, but you will get there with the patience of a zen master
here's a video that shows the extra steps of remo9ving and replacing keyboard: https://www.youtube.com/watch?v=DpawPQrq...
tom - Réponse
I'm only 13 and it was easy to get to the dvd-rw drive and unjam it, little hands made the keyboard cable a breeze.
tha B-BOY - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 40
Total : 12,178
