Aller au contenu principal
Acer Aspire E5-571-58CG Power Jack Replacement
Ce dont vous avez besoin
  1. Acer Aspire E5-571-58CG Power Jack Replacement, Battery: étape 1, image 1 de 2 Acer Aspire E5-571-58CG Power Jack Replacement, Battery: étape 1, image 2 de 2
    • Make sure the laptop is powered off.
    • Flip the laptop over and locate the battery release switch.
    • Insert the pointed end of the spudger into the battery release switch.
    • Push the battery release switch to the right.
  2. Acer Aspire E5-571-58CG Power Jack Replacement: étape 2, image 1 de 3 Acer Aspire E5-571-58CG Power Jack Replacement: étape 2, image 2 de 3 Acer Aspire E5-571-58CG Power Jack Replacement: étape 2, image 3 de 3
    • While the battery release switch is pushed to the right, carefully slide the battery out of its socket.
  3. Acer Aspire E5-571-58CG Power Jack Replacement, Power Jack: étape 3, image 1 de 3 Acer Aspire E5-571-58CG Power Jack Replacement, Power Jack: étape 3, image 2 de 3 Acer Aspire E5-571-58CG Power Jack Replacement, Power Jack: étape 3, image 3 de 3
    • Remove the top panel of the laptop with the plastic opening tool.
  4. Acer Aspire E5-571-58CG Power Jack Replacement: étape 4, image 1 de 2 Acer Aspire E5-571-58CG Power Jack Replacement: étape 4, image 2 de 2
    • Remove the plastic safeguard from the CD drive slot.
  5. Acer Aspire E5-571-58CG Power Jack Replacement: étape 5, image 1 de 3 Acer Aspire E5-571-58CG Power Jack Replacement: étape 5, image 2 de 3 Acer Aspire E5-571-58CG Power Jack Replacement: étape 5, image 3 de 3
    • Remove the marked screws with the JIS #00 screwdriver.
  6. Acer Aspire E5-571-58CG Power Jack Replacement: étape 6, image 1 de 2 Acer Aspire E5-571-58CG Power Jack Replacement: étape 6, image 2 de 2
    • Disconnect the opposite end of the power jack from the motherboard by carefully pulling the wire.
  7. Acer Aspire E5-571-58CG Power Jack Replacement: étape 7, image 1 de 2 Acer Aspire E5-571-58CG Power Jack Replacement: étape 7, image 2 de 2
    • Lift the bottom right side of the screen to move the metal plate covering the power jack.
  8. Acer Aspire E5-571-58CG Power Jack Replacement: étape 8, image 1 de 2 Acer Aspire E5-571-58CG Power Jack Replacement: étape 8, image 2 de 2
    • Carefully lift the power jack out of the laptop.
Aliana Johnson
Membre depuis le 10/24/18
145 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S7-G7, Valliere Fall 2018 Membre de l'équipe UMass Dartmouth, Team S7-G7, Valliere Fall 2018
UMASSD-VALLIERE-F18S7G7
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 10
Total : 1,338
