Aller au contenu principal
Acer Aspire E5-571P-55TL CPU Fan Replacement
Ce dont vous avez besoin
  1. Acer Aspire E5-571P-55TL CPU Fan Replacement, Battery: étape 1, image 1 de 1
    • Make sure that laptop is turned off.
    • Turn the laptop upside down with the battery facing you.
  2. Acer Aspire E5-571P-55TL CPU Fan Replacement: étape 2, image 1 de 1
    • Place the Spudger into the battery lock and slide it to the left until you hear the battery unlock.
  3. Acer Aspire E5-571P-55TL CPU Fan Replacement: étape 3, image 1 de 2 Acer Aspire E5-571P-55TL CPU Fan Replacement: étape 3, image 2 de 2
    • Pull the battery towards you to remove it from the laptop.
  4. Acer Aspire E5-571P-55TL CPU Fan Replacement, Keyboard: étape 4, image 1 de 2 Acer Aspire E5-571P-55TL CPU Fan Replacement, Keyboard: étape 4, image 2 de 2
    • Using a Phillips #0 screwdriver, remove each of the eighteen 8 mm screws from the bottom of the laptop.
  5. Acer Aspire E5-571P-55TL CPU Fan Replacement: étape 5, image 1 de 3 Acer Aspire E5-571P-55TL CPU Fan Replacement: étape 5, image 2 de 3 Acer Aspire E5-571P-55TL CPU Fan Replacement: étape 5, image 3 de 3
    • Carefully place your fingers underneath the top of the keyboard just below the screen.
    • Pull upwards until you can hear the keyboard click out of place.
    • Continue around the entire laptop, carefully pulling the keyboard and palm rest assembly slightly from the frame to reveal the ribbon connectors.
    • Don't pull the keyboard off the frame yet because it's attached by ribbon connectors.
    • After the keyboard is detached, unplug each of the three ribbon cables and remove the keyboard and palm rest assembly.
  6. Acer Aspire E5-571P-55TL CPU Fan Replacement, CPU Fan: étape 6, image 1 de 2 Acer Aspire E5-571P-55TL CPU Fan Replacement, CPU Fan: étape 6, image 2 de 2
    • Before replacing the CPU fan, you'll have to remove the network card found below the fan.
    • Using a Philips #0 screwdriver, remove the two 3 mm screws from the corners of the Wi-Fi card.
    • Carefully lift the network card from it's slot, and disconnect the two coaxial cables.
  7. Acer Aspire E5-571P-55TL CPU Fan Replacement: étape 7, image 1 de 2 Acer Aspire E5-571P-55TL CPU Fan Replacement: étape 7, image 2 de 2
    • The CPU fan can be found in the upper left corner of the laptop.
    • Using a Phillips #0 screwdriver, remove the two 4.5 mm screws from the fan.
  8. Acer Aspire E5-571P-55TL CPU Fan Replacement: étape 8, image 1 de 2 Acer Aspire E5-571P-55TL CPU Fan Replacement: étape 8, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Use tweezers to safely remove the fan plug from the motherboard. To remove the plug, gently push left.
  9. Acer Aspire E5-571P-55TL CPU Fan Replacement: étape 9, image 1 de 1
    • Make sure that all fan wires are disconnected from the board.
    • Lift the curved end of the fan, and safely remove it.
Max Piekos
Membre depuis le 03/23/22
459 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team B-1, Gurgel Spring 2022 Membre de l'équipe UMass Dartmouth, Team B-1, Gurgel Spring 2022
UMASSD-GURGEL-S22SBG1
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 154
