Aller au contenu principal
Introduction
If your laptop wont boot, it may be because of a corrupted hard drive. This simple guide will show you how to remove the hard drive for this laptop. Be sure to fallow the steps in order. In the end you will be able to remove and replace the current hard drive.
  1. Remove the twenty-five 6mm Phillips #0 screws from the bottom panel of the laptop.
    • Remove the twenty-five 6mm Phillips #0 screws from the bottom panel of the laptop.
  2. Using the plastic opening tool, lift up on the side opposite of the Ethernet connector.
    • Using the plastic opening tool, lift up on the side opposite of the Ethernet connector.
    • With the plastic opening tool under the bottom panel, work your way around the perimeter until the panel separates.
  3. Fix Kits pour batteries d'iPhone
    Seulement $29.99
    Buy Now
    Seulement $29.99
    Buy Now
  4. Remove the two 6mm Phillips #0 screws from the battery.
    • Remove the two 6mm Phillips #0 screws from the battery.
  5. Disconnect the battery from the motherboard. Pull the battery up and out of the laptop.
    • Disconnect the battery from the motherboard.
    • Pull the battery up and out of the laptop.
  6. Remove the four 3mm Phillips #0 screws from the hard drive.
    • Remove the four 3mm Phillips #0 screws from the hard drive.
  7. Use a spudger to flip up the retaining flap on the hard drive ribbon cable ZIF socket.
    • Use a spudger to flip up the retaining flap on the hard drive ribbon cable ZIF socket.
    • Pull the ribbon cable out of the ZIF connector and remove the hard drive from the laptop.
Ed Herrera
Membre depuis le 25/01/2018
385 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S7-G3, Passmore Spring 2018 Membre de l'équipe USF Tampa, Team S7-G3, Passmore Spring 2018
USFT-PASSMORE-S18S7G3
4 membres
6 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 15
Total : 174
