Aller au contenu principal
Acer Aspire ES1-711-P1UV Fan Replacement
Ce dont vous avez besoin
  1. Acer Aspire ES1-711-P1UV Fan Replacement, Battery: étape 1, image 1 de 1
    • Place the laptop face down on a flat, clean surface.
    • Remove all twenty-seven 7 mm screws on the back cover of the laptop with a Phillips #0 screwdriver. Screws are circled in red on the diagram.
  2. Acer Aspire ES1-711-P1UV Fan Replacement: étape 2, image 1 de 1
    • Use the iFixit opening tool to pry open the four corners of the back cover of the laptop. You may need to use your hands to fully remove the cover.
    • Be sure to evenly apply pressure when removing the back cover.
  3. Acer Aspire ES1-711-P1UV Fan Replacement: étape 3, image 1 de 1
    • Remove the two 5 mm screws located on either side of the battery.
  4. Acer Aspire ES1-711-P1UV Fan Replacement: étape 4, image 1 de 1
    • Disconnect the colored bundled cable connectors from the motherboard. To do this, pull on the wires to disconnect the cable and remove the battery.
  5. Acer Aspire ES1-711-P1UV Fan Replacement, Fan: étape 5, image 1 de 1
    • Locate and remove the 5 mm screw using the Phillips #0 screwdriver.
    • Unscrew the four 5mm screws still holding down the fan.
    • The four 5mm screws in the second part of this step cannot be fully removed from the fan. Loosen them and continue on to Step 6.
  6. Acer Aspire ES1-711-P1UV Fan Replacement: étape 6, image 1 de 3 Acer Aspire ES1-711-P1UV Fan Replacement: étape 6, image 2 de 3 Acer Aspire ES1-711-P1UV Fan Replacement: étape 6, image 3 de 3
    • Disconnect the red, white, black, and yellow bundled cable connectors from the motherboard by gently pulling them.
    • Remove the fan assembly.
2 autres ont terminé cette réparation.
Lindsay O'Shea
Membre depuis le 03/22/18
429 Réputation
3 tutoriels rédigés
Équipe
Sam Houston State, Team S17-G3, Blackburne Spring 2018 Membre de l'équipe Sam Houston State, Team S17-G3, Blackburne Spring 2018
SHSU-BLACKBURNE-S18S17G3
3 membres
3 tutoriels rédigés
0Commentaires sur le guide
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 2
Total : 691
