Introduction
In this guide you will learn to remove your current Acer Aspire M5 fan and then you can repeat the steps in reverse to install a new one.
  1. Remove all 18 of the marked screws (2.12 mm) using a Phillips #1 Screwdriver.
    • Remove all 18 of the marked screws (2.12 mm) using a Phillips #1 Screwdriver.
  2. Use the spudger to slowly and gently work your away around the device, popping the bottom cover off the device. Use the spudger to slowly and gently work your away around the device, popping the bottom cover off the device.
    • Use the spudger to slowly and gently work your away around the device, popping the bottom cover off the device.
  3. %Livraison gratuite pour toute commande supérieure à 100 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
  4. Remove the four marked screws (2.31mm) using a Phillips #1 Screwdriver. Remove the four marked screws (2.31mm) using a Phillips #1 Screwdriver.
    • Remove the four marked screws (2.31mm) using a Phillips #1 Screwdriver.
  5. After the screws are removed, you will need to unplug it from the motherboard shown by the red rectangle. After it  is unplugged, then you will be able to remove the fan completely. After the screws are removed, you will need to unplug it from the motherboard shown by the red rectangle. After it  is unplugged, then you will be able to remove the fan completely.
    • After the screws are removed, you will need to unplug it from the motherboard shown by the red rectangle. After it is unplugged, then you will be able to remove the fan completely.
2 autre(s) ont terminé cette réparation.
Jarrett Tuggle
Membre depuis le 29/01/2018
233 Réputation
1 tutoriel rédigé
Équipe
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 79
