Aller au contenu principal
Acer Aspire One 722 Keyboard Keys and Battery Replacement
Ce dont vous avez besoin
  1. Acer Aspire One 722 Keyboard Keys and Battery Replacement, Battery: étape 1, image 1 de 1
    • Power down the netbook by pressing the power button on the top left corner.
  2. Acer Aspire One 722 Keyboard Keys and Battery Replacement: étape 2, image 1 de 1
    • Close the netbook and flip it over so that the back is facing up.
  3. Acer Aspire One 722 Keyboard Keys and Battery Replacement: étape 3, image 1 de 1
    • Slide the button below the battery to the right while simultaneously pulling the battery out.
  4. Acer Aspire One 722 Keyboard Keys and Battery Replacement: étape 4, image 1 de 2 Acer Aspire One 722 Keyboard Keys and Battery Replacement: étape 4, image 2 de 2
    • If necessary, remove the old battery and replace it with a new one.
  5. Acer Aspire One 722 Keyboard Keys and Battery Replacement: étape 5, image 1 de 1
    • Check the thin grooves on the side of the battery entry and line the replacement battery up to the grooves.
  6. Acer Aspire One 722 Keyboard Keys and Battery Replacement, Keyboard Keys and Battery: étape 6, image 1 de 1
    • Use the flat end of a spudger to pry off the keyboard key.
    • If the key is broken, just remove the broken key and press a new key down over the empty key area. If you need to repair the key, follow the steps below.
  7. Acer Aspire One 722 Keyboard Keys and Battery Replacement: étape 7, image 1 de 2 Acer Aspire One 722 Keyboard Keys and Battery Replacement: étape 7, image 2 de 2
    • Use a spudger to pry the upper portion on both sides of the mechanism until it pops off from the key socket.
  8. Acer Aspire One 722 Keyboard Keys and Battery Replacement: étape 8, image 1 de 3 Acer Aspire One 722 Keyboard Keys and Battery Replacement: étape 8, image 2 de 3 Acer Aspire One 722 Keyboard Keys and Battery Replacement: étape 8, image 3 de 3
    • Take both pivoting pieces of the mechanism and put them together.
    • The smaller piece fits through the inner part of the larger piece and lays in the groove of the larger piece.
    • Once assembled, it should be entirely flat.
  9. Acer Aspire One 722 Keyboard Keys and Battery Replacement: étape 9, image 1 de 1
    • Position the pivoting smaller piece of the key mechanism in the lower hooks of the key socket.
    • Slide your finger across the upper portion of the key mechanism so that it locks in place with the upper hooks of the key socket.
  10. Acer Aspire One 722 Keyboard Keys and Battery Replacement: étape 10, image 1 de 1
    • Place the key on top of the empty key space and press it down firmly until the key locks in place.
Christian Barboza
Membre depuis le 10/25/15
818 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015 Membre de l'équipe UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G6
3 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 18
Total : 4,443
