Introduction
Replacing the hinges requires many steps as well as going through step 3(step 13 in this guide) of the individual key guide and starting back at step 17. It has many parts so it is important to be careful.
Ce dont vous avez besoin
With your fingers, remove 6 rubber coverings located at the edges of screen. The rubber coverings are held in place with a small amount of adhesive, but you should be able to peel them off easily.
Disconnect the microphone, which located left of the camera piece, by pinching the tape around the wires, pinching the microphone, and pulling the two in opposite directions. This microphone is detached in the same way the camera was detached.
To remove the keyboard, place the Blue Plastic Opening Tool at the 3 indentations above the keyboard as shown.
Slip the Blue Plastic Opening Tool in the space between the keyboard and the pink plastic casing and push down.
Pushing down on all 3 indentations should cause the keyboard to pop upwards slightly.
Use the Blue Plastic opening tool and your fingers to pull up the top part of the keyboard as shown.
Use the Blue Plastic Opening Tool to separate the right side of the casing from the keyboard as shown.
After you have successfully moved the keyboard out from under the notch, pull the keyboard up.
With your fingers, pull the blue plastic tab connected to the white connector at the bottom of the laptop to disconnect the trackpad from the motherboard.
To detach the bottom white casing from the netbook, a total of 8 screws must be removed using the Phillips #1 screwdriver.
Using the Phillips #1 screwdriver, remove three 5.2mm screws located at the bottom of the plastic casing.
Using the Phillips #1 screwdriver, remove three 3.78mm screws located in the middle of the casing.
Un commentaire
Great instruction. Thanks for taking the time to help others! One of the best guides I have seen. Thank You !
