Aller au contenu principal
Acer Aspire One D255-1625 Keyboard Replacement
Ce dont vous avez besoin
  1. Acer Aspire One D255-1625 Keyboard Replacement, Battery: étape 1, image 1 de 3 Acer Aspire One D255-1625 Keyboard Replacement, Battery: étape 1, image 2 de 3 Acer Aspire One D255-1625 Keyboard Replacement, Battery: étape 1, image 3 de 3
    • Before you replace the battery, ensure that the device is unplugged and powered off.
    • Pull the upper left switch on the back of the laptop to the left into the unlock position.
    • Pull the upper right switch to the left and hold it in place.
  2. Acer Aspire One D255-1625 Keyboard Replacement: étape 2, image 1 de 1
    • Pull the battery straight out.
    • To properly dispose of battery, locate your nearest recycling plant to dispose of it there.
  3. Acer Aspire One D255-1625 Keyboard Replacement, Keyboard: étape 3, image 1 de 2 Acer Aspire One D255-1625 Keyboard Replacement, Keyboard: étape 3, image 2 de 2
    • Use iFixit's Jimmy tool and press it into the small tabs at the top of the keyboard and lift up.
    • Do this for all five tabs at the top of the keyboard.
  4. Acer Aspire One D255-1625 Keyboard Replacement: étape 4, image 1 de 1
    • Slide the Jimmy tool along the top of the keyboard once all tabs have been pressed in.
  5. Acer Aspire One D255-1625 Keyboard Replacement: étape 5, image 1 de 3 Acer Aspire One D255-1625 Keyboard Replacement: étape 5, image 2 de 3 Acer Aspire One D255-1625 Keyboard Replacement: étape 5, image 3 de 3
    • Flip the keyboard forward to expose its connection.
    • Slide the small brown tab out to disconnect the keyboard.
    • Lift the keyboard away from the laptop.
    • If you see that the keyboard is not connected upon flipping, reconnect it and see if it works. If not, continue to replace the keyboard.
Zahria Martin
Membre depuis le 01/30/20
196 Réputation
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 15
Total : 275
