Aller au contenu principal
Acer Aspire One ZG5 Keyboard Replacement
Ce dont vous avez besoin
  1. Acer Aspire One ZG5 Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Turn the netbook upside down with the battery at the top, facing away from you.
  2. Acer Aspire One ZG5 Keyboard Replacement: étape 2, image 1 de 1
    • Unlock the battery by sliding the switch located near the left hinge to the left "unlocked" position.
  3. Acer Aspire One ZG5 Keyboard Replacement: étape 3, image 1 de 1
    • Slide the latch located on the opposite hinge from the lock while pushing the battery up.
  4. Acer Aspire One ZG5 Keyboard Replacement, Keyboard: étape 4, image 1 de 1
    • Turn the netbook over and open the display so that the keyboard is facing you.
  5. Acer Aspire One ZG5 Keyboard Replacement: étape 5, image 1 de 3 Acer Aspire One ZG5 Keyboard Replacement: étape 5, image 2 de 3 Acer Aspire One ZG5 Keyboard Replacement: étape 5, image 3 de 3
    • There are three tabs located on the top of the keyboard.
    • Start with the spudger pointing towards the display and pry up to push each tab off the keyboard.
    • As you move to the next tab, ensure the previous tab doesn't reset itself.
  6. Acer Aspire One ZG5 Keyboard Replacement: étape 6, image 1 de 2 Acer Aspire One ZG5 Keyboard Replacement: étape 6, image 2 de 2
    • Lift top of keyboard up. If it doesn't lift easily, there may be tabs on the sides - use the tool to ease them aside and/or shift the keyboard from side to side.
    • There is a short ribbon cable connecting the keyboard to the netbook.
  7. Acer Aspire One ZG5 Keyboard Replacement: étape 7, image 1 de 2 Acer Aspire One ZG5 Keyboard Replacement: étape 7, image 2 de 2
    • Disconnect the ribbon by lifting the black plastic hinge and removing the clear blue cable.
12 autres ont terminé cette réparation.
Doug Gallatin
Membre depuis le 10/05/10
6 337 Réputation
10 tutoriels rédigés
Équipe
Cal Poly, Team 7-49, Amido Fall 2010 Membre de l'équipe Cal Poly, Team 7-49, Amido Fall 2010
CPSU-AMIDO-F10S7G49
5 membres
27 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 22
Total : 24,623
