Aller au contenu principal
Acer Aspire R5-471T-52EE Battery Replacement
Ce dont vous avez besoin
  1. Acer Aspire R5-471T-52EE Battery Replacement, Back Cover: étape 1, image 1 de 2 Acer Aspire R5-471T-52EE Battery Replacement, Back Cover: étape 1, image 2 de 2
    • Unplug the laptop and turn it off.
    • Remove the twelve 3mm screws using the Phillips #1 screwdriver.
  2. Acer Aspire R5-471T-52EE Battery Replacement: étape 2, image 1 de 1
    • With the hinges of the laptop pointing away from you, gently begin to pull on the portion between the two hinges towards yourself until you feel the cover pop off.
    • Remove the back cover from the device.
  3. Acer Aspire R5-471T-52EE Battery Replacement, Battery: étape 3, image 1 de 1
    • Using your fingers, gently disconnect the battery plug from the motherboard.
    • Remove the two screws using a Phillips #00 screwdriver.
    • Remove the battery from the device.
3 autres ont terminé cette réparation.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 11
Total : 1,029
