Aller au contenu principal
Acer Aspire R5-471T-52EE Motherboard Replacement
Ce dont vous avez besoin
  1. Acer Aspire R5-471T-52EE Motherboard Replacement, Back Cover: étape 1, image 1 de 2 Acer Aspire R5-471T-52EE Motherboard Replacement, Back Cover: étape 1, image 2 de 2
    • Unplug the laptop and turn it off.
    • Remove the twelve 3mm screws using the Phillips #1 screwdriver.
  2. Acer Aspire R5-471T-52EE Motherboard Replacement: étape 2, image 1 de 1
    • With the hinges of the laptop pointing away from you, gently begin to pull on the portion between the two hinges towards yourself until you feel the cover pop off.
    • Remove the back cover from the device.
  3. Acer Aspire R5-471T-52EE Motherboard Replacement, Motherboard: étape 3, image 1 de 1
    • Remove seven 3 mm screws using the Phillips #00 screwdriver.
  4. Acer Aspire R5-471T-52EE Motherboard Replacement: étape 4, image 1 de 1
    • Once the screws are removed, disconnect seven plugs from the motherboard.
    • Keep in mind that a majority of these wires are extremely thin and fragile. Disconnect them with light force and care.
  5. Acer Aspire R5-471T-52EE Motherboard Replacement: étape 5, image 1 de 1
    • Flip up the small black portion the connectors are connected to and disconnect them from the motherboard.
    • Grab the yellow piece of tape to easily remove the connection from the motherboard with nothing more than some gentle force.
    • Remove the large black ribbon wire by gently pulling on the white tab towards yourself.
    • Remove the large white ribbon wire by pulling up on the small black tab.
  6. Acer Aspire R5-471T-52EE Motherboard Replacement: étape 6, image 1 de 1
    • Remove the four remaining screws located on the fan using the Phillips #00 screwdriver.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 10
Total : 579
