Aller au contenu principal
Acer Aspire R5-471T-52EE Speakers Replacement
Ce dont vous avez besoin
  1. Acer Aspire R5-471T-52EE Speakers Replacement, Back Cover: étape 1, image 1 de 2 Acer Aspire R5-471T-52EE Speakers Replacement, Back Cover: étape 1, image 2 de 2
    • Unplug the laptop and turn it off.
    • Remove the twelve 3mm screws using the Phillips #1 screwdriver.
  2. Acer Aspire R5-471T-52EE Speakers Replacement: étape 2, image 1 de 1
    • With the hinges of the laptop pointing away from you, gently begin to pull on the portion between the two hinges towards yourself until you feel the cover pop off.
    • Remove the back cover from the device.
  3. Acer Aspire R5-471T-52EE Speakers Replacement, Battery: étape 3, image 1 de 1
    • Using your fingers, gently disconnect the battery plug from the motherboard.
    • Remove the two screws using a Phillips #00 screwdriver.
    • Remove the battery from the device.
  4. Acer Aspire R5-471T-52EE Speakers Replacement, Speakers: étape 4, image 1 de 2 Acer Aspire R5-471T-52EE Speakers Replacement, Speakers: étape 4, image 2 de 2
    • Gently peel off all of the black take that sticks down the speaker cables.
    • Disconnect the two ribbon cables to allow the speaker cable to be removed from underneath.
    • Unplug the speaker cable from the motherboard.
    • Using a spudger, gently remove the speakers from the device.
Un commentaire
I want to replace my laptop speakers but I am not getting them from anywhere, please send a purchase link also if you have the same speakers. email : prdp9101.com@gmail.com
pradeep singh - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 11
Total : 256
