Aller au contenu principal
Acer Aspire R5-571T-57Z0 Display Assembly Replacement
Ce dont vous avez besoin
  1. Acer Aspire R5-571T-57Z0 Display Assembly Replacement, Battery: étape 1, image 1 de 2 Acer Aspire R5-571T-57Z0 Display Assembly Replacement, Battery: étape 1, image 2 de 2
    • Remove the three 4.0 mm screws from the battery using a Phillips #00 screwdriver.
    • Unplug the cable connected to the RAM.
    • Carefully remove the battery.
  2. Acer Aspire R5-571T-57Z0 Display Assembly Replacement, Display Assembly: étape 2, image 1 de 2 Acer Aspire R5-571T-57Z0 Display Assembly Replacement, Display Assembly: étape 2, image 2 de 2
    • Remove the six 4.0 mm screws from the hinges using a Phillips #00 screwdriver.
  3. Acer Aspire R5-571T-57Z0 Display Assembly Replacement: étape 3, image 1 de 2 Acer Aspire R5-571T-57Z0 Display Assembly Replacement: étape 3, image 2 de 2
    • Peel back the stickers from the display cable.
  4. Acer Aspire R5-571T-57Z0 Display Assembly Replacement: étape 4, image 1 de 3 Acer Aspire R5-571T-57Z0 Display Assembly Replacement: étape 4, image 2 de 3 Acer Aspire R5-571T-57Z0 Display Assembly Replacement: étape 4, image 3 de 3
    • Hold back the film protecting the Wi-Fi card.
    • Disconnect the touch screen cable.
  5. Acer Aspire R5-571T-57Z0 Display Assembly Replacement: étape 5, image 1 de 2 Acer Aspire R5-571T-57Z0 Display Assembly Replacement: étape 5, image 2 de 2
    • Pull back the tape covering the connectors.
    • Detach the two connectors (one black wire, one white wire).
  6. Acer Aspire R5-571T-57Z0 Display Assembly Replacement: étape 6, image 1 de 2 Acer Aspire R5-571T-57Z0 Display Assembly Replacement: étape 6, image 2 de 2
    • Disconnect the touch control cable next to the black film.
  7. Acer Aspire R5-571T-57Z0 Display Assembly Replacement: étape 7, image 1 de 2 Acer Aspire R5-571T-57Z0 Display Assembly Replacement: étape 7, image 2 de 2
    • Flip over the laptop and pull back to remove the display assembly.
Kevin Chen
Membre depuis le 03/23/22
133 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 1-2, Botvin Spring 2022 Membre de l'équipe UMass Dartmouth, Team 1-2, Botvin Spring 2022
UMASSD-BOTVIN-S22S1G2
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 8
Total : 225
