Aller au contenu principal
Acer Aspire S3-391-6046 Keyboard Replacement
Ce dont vous avez besoin
  1. Acer Aspire S3-391-6046 Keyboard Replacement, Back Cover: étape 1, image 1 de 1
    • Place laptop upside down.
  2. Acer Aspire S3-391-6046 Keyboard Replacement: étape 2, image 1 de 2 Acer Aspire S3-391-6046 Keyboard Replacement: étape 2, image 2 de 2
    • Remove the twelve 5mm screws with a Phillips #1 screwdriver.
  3. Acer Aspire S3-391-6046 Keyboard Replacement: étape 3, image 1 de 1
    • Lift cover upwards away from you.
  4. Acer Aspire S3-391-6046 Keyboard Replacement, Keyboard: étape 4, image 1 de 3 Acer Aspire S3-391-6046 Keyboard Replacement, Keyboard: étape 4, image 2 de 3 Acer Aspire S3-391-6046 Keyboard Replacement, Keyboard: étape 4, image 3 de 3
    • Remove the four Phillips #0 screws that are connected to the left and right speakers.
    • Carefully disconnect the wires that connect the speaker to the rest of the computer.
  5. Acer Aspire S3-391-6046 Keyboard Replacement: étape 5, image 1 de 1
    • Remove two Phillips #0 screws that are beside the ends of the gray wire.
  6. Acer Aspire S3-391-6046 Keyboard Replacement: étape 6, image 1 de 3 Acer Aspire S3-391-6046 Keyboard Replacement: étape 6, image 2 de 3 Acer Aspire S3-391-6046 Keyboard Replacement: étape 6, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Remove the gray wire slowly with tweezers.
    • Carefully peel wire off.
  7. Acer Aspire S3-391-6046 Keyboard Replacement: étape 7, image 1 de 2 Acer Aspire S3-391-6046 Keyboard Replacement: étape 7, image 2 de 2
    • Slowly remove the two wires that are to the left of the battery with tweezers in an upward pulling motion.
  8. Acer Aspire S3-391-6046 Keyboard Replacement: étape 8, image 1 de 2 Acer Aspire S3-391-6046 Keyboard Replacement: étape 8, image 2 de 2
    • Completely remove the battery out of its position.
  9. Acer Aspire S3-391-6046 Keyboard Replacement: étape 9, image 1 de 2 Acer Aspire S3-391-6046 Keyboard Replacement: étape 9, image 2 de 2
    • Remove the five Phillips #0 screws that are on the border of the laptop.
    • Disconnect the white wire that is below the fan.
  10. Acer Aspire S3-391-6046 Keyboard Replacement: étape 10, image 1 de 2 Acer Aspire S3-391-6046 Keyboard Replacement: étape 10, image 2 de 2
    • Flip all of the circuits upwards.
    • Remove all Phillips #0 screws.
    • Remove the keyboard.
Brian Jimenez
Membre depuis le 09/18/18
145 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 15
Total : 835
