Aller au contenu principal
Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement
Ce dont vous avez besoin
  1. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement, Speakers: étape 1, image 1 de 3 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement, Speakers: étape 1, image 2 de 3 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement, Speakers: étape 1, image 3 de 3
    • Wedge your plastic opening tool into the crevice between the volume button and casing to create space.
    • Slide the plastic opening tool along this crevice to pry apart the backing of the tablet.
  2. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: étape 2, image 1 de 3 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: étape 2, image 2 de 3 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: étape 2, image 3 de 3
    • There is one zero insertion force connector that needs to be removed.
    • Use your plastic opening tool to flip up the black clip that secures the ribbon cable to the motherboard.
    • Once the clip is flipped up, the ribbon cable will be safe to remove.
  3. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: étape 3, image 1 de 3 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: étape 3, image 2 de 3 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: étape 3, image 3 de 3
    • To remove the four bundled cable connectors, push against the edges of the connector to loosen it up.
    • Pull the cable away from the connector.
  4. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: étape 4, image 1 de 2 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: étape 4, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Use a pair of tweezers to gently pull up the speaker closest to the motherboard.
  5. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: étape 5, image 1 de 2 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: étape 5, image 2 de 2
    • Remove any tape that may be holding down the speakers or wires in place.
  6. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: étape 6, image 1 de 2 Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: étape 6, image 2 de 2
    • Use tweezers to gently pull up the second speaker.
  7. Acer Aspire Switch 10 SW5-011-18R3 Speakers Replacement: étape 7, image 1 de 1
    • Remove and replace the speakers.
2 autres ont terminé cette réparation.
Richard Colon
Membre depuis le 09/28/16
480 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 3-4, Passmore Fall 2016 Membre de l'équipe USF Tampa, Team 3-4, Passmore Fall 2016
USFT-PASSMORE-F16S3G4
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 15
Total : 1,358
