Aller au contenu principal
Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement
Ce dont vous avez besoin
  1. Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement, Touchpad: étape 1, image 1 de 1
    • Use the Driver with the Phillips PH0 attachment to unscrew the 7 5mm screws from the back panel.
    • This screw does not need to be removed because it doesn't hold the backplate in.
  2. Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: étape 2, image 1 de 2 Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: étape 2, image 2 de 2
    • Push the plastic opening tool into the crevice between the front and back panel.
    • Pull down on the plastic opening tool like a lever to create space and slide along the crevice to remove the back panel.
  3. Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: étape 3, image 1 de 3 Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: étape 3, image 2 de 3 Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: étape 3, image 3 de 3
    • Gently slide the plastic opening tool under the black clip that is attached to the ribbon cable.
    • Pull down on the plastic opening tool like a lever to flip the black clip and remove the ribbon cable.
    • The black clip doesn't take much force to lift, so be gentle to avoid breaking it.
  4. Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: étape 4, image 1 de 1
    • Remove the touchpad.
Max Francois
Membre depuis le 09/28/16
684 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 3-4, Passmore Fall 2016 Membre de l'équipe USF Tampa, Team 3-4, Passmore Fall 2016
USFT-PASSMORE-F16S3G4
4 membres
4 tutoriels rédigés
Un commentaire
Thank you for the steps. I want to know if a replacement keyboard is available in the market. I did not find online.
Gibson Castelino - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 12
Total : 1,573
