Aller au contenu principal
Acer Aspire TimelineU M5-481TG Keyboard Replacement
Ce dont vous avez besoin
  1. Acer Aspire TimelineU M5-481TG Keyboard Replacement, Keyboard: étape 1, image 1 de 1
    • With the laptop closed and powered off, place the laptop screen side down.
    • Turn the laptop so that the hinges are closest to you.
    • Remove sixteen 6 mm screws from the bottom of the laptop with the Phillips #00 screwdriver.
  2. Acer Aspire TimelineU M5-481TG Keyboard Replacement: étape 2, image 1 de 2 Acer Aspire TimelineU M5-481TG Keyboard Replacement: étape 2, image 2 de 2
    • Flip the laptop over and open the lid.
    • Use the plastic opening tool with the half centimeter wide tip to gently separate the bottom case of the laptop from the keyboard.
    • Potential for device damage: Do not apply too much force or you may break the clips.
    • Gently pull the keyboard upwards to a 45 degree angle.
  3. Acer Aspire TimelineU M5-481TG Keyboard Replacement: étape 3, image 1 de 3 Acer Aspire TimelineU M5-481TG Keyboard Replacement: étape 3, image 2 de 3 Acer Aspire TimelineU M5-481TG Keyboard Replacement: étape 3, image 3 de 3
    • Hold the keyboard open with one hand to extend the three cables (white, black and copper) still connecting the bottom of the keyboard to the back case.
    • Be sure you are prying up the hinged retaining flap, not the connector itself.
    • Use your fingernail to flip up the small retaining flap of each zero insertion force connector and then gently pull each ribbon cable out one at a time.
    • The white line on this ribbon cable marks the edge of the connection area. To reinstall, insert the cable into the connector up to this line and then close the retaining flap. If the cable doesn’t insert easily up to (or very near to) this line, it’s probably misaligned and needs to be gently removed and repositioned.
  4. Acer Aspire TimelineU M5-481TG Keyboard Replacement: étape 4, image 1 de 2 Acer Aspire TimelineU M5-481TG Keyboard Replacement: étape 4, image 2 de 2
    • Use both hands to remove the keyboard.
    • Potential for device damage: Do not pull too forcibly or you could damage your keyboard.
3 autres ont terminé cette réparation.
Christina Crasto
Membre depuis le 03/07/16
475 Réputation
3 tutoriels rédigés
Équipe
Marist, Team 1-2, Laflen Spring 2016 Membre de l'équipe Marist, Team 1-2, Laflen Spring 2016
MARS-LAFLEN-S16S1G2
3 membres
6 tutoriels rédigés
Un commentaire
my problem is how to replace the keyboard not how to dismantle it
roniejunbautista - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 18
Total : 2,755
