Introduction
This guide teaches you how to replace the hard drive in an Acer Aspire M5-581T-6807 Ultrabook.
Ce dont vous avez besoin
Open the lid othe the netbook. Use the Jimmy from the upper left corner of the keyboard. Put it between the keyboard and th casing and move it to the right. It might help to use a metal spudger to push in the pins holding the keyboard in place.
Then move down along the sides where there is one pin on each side. After that twist the keyboard towards you.
Remove the 12 screws securing the palmrest.
Slowly lift the palmrest up at the front, and stop when you feel the cable slack run out.
Remove the tape covering the connectors.
Unlock the three connectors, and remove their cables.
Continue to lift the palmrest upwards in the front, to the point that it hinges over onto the laptop screen, so as not to pull on the remaining cable on the palmrest. You don't need to disconnect this one.
Remove the four short screws securing the hard drive caddy to the base.
Remove the screws securing the caddy to the hard drive. You're done!
5 autres ont terminé cette réparation.
