Introduction
Removing the keyboard may take a some effort and a little bit of patience, but you can do it!
Locate and remove the two 5.3 mm Phillips #1 screws holding the back panel in place.
  • Locate and remove the two 5.3 mm Phillips #1 screws holding the back panel in place.
Ajouter un commentaire
Use a spudger to pry the panel up from the laptop case and remove it.
  • Use a spudger to pry the panel up from the laptop case and remove it.
  • The laptop should now be open with the RAM and wifi chip now accessible.
  • Locate the wifi chip.
  • Remove the 5 mm Phillips #1 screw holding the wifi chip in place.
  • Carefully remove the wifi chip.
  • Remove the 8, 9 mm Phillips #1 screws holding the panel in place.
  • Flip the computer over, and with a spudger, remove the black panel directly below the keyboard.
  • Remove the panel and flip it up onto the keyboard
  • With the panel removed, locate the USB port ribbon cable connecting to the motherboard.
  • Carefully disconnect the ribbon cable.
  • Unscrew the 5 mm Phillips #1 screw holding the USB ports in place.
  • The USB ports can now be removed from the laptop.
  • Flip the laptop and remove all 10 of the remaining 9mm screws from the back.
I had to remove 11 screws. The one underneath the battery.
sj.408.shane - Réponse
  • Use a spudger to gently lift the keyboard.
The photos for Step 11 show the USB ports still in place. Why did you remove them in Step 9 if it wasn't necessary?
richmaru - Réponse
2 autre(s) ont terminé cette réparation.
Alexander Lazar
Membre depuis le 22/04/2014
306 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 8-8, Regan Spring 2014 Membre de l'équipe Cal Poly, Team 8-8, Regan Spring 2014
CPSU-REGAN-S14S8G8
4 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 57
Total : 4,848
