Introduction
USB is essential on modern laptops. Use this guide to fix your broken ports.
  1. Locate and remove the two 5.3 mm Phillips #1 screws holding the back panel in place.
    • Locate and remove the two 5.3 mm Phillips #1 screws holding the back panel in place.
  2. Use a spudger to pry the panel up from the laptop case and remove it. The laptop should now be open with the RAM and wifi chip now accessible.
    • Use a spudger to pry the panel up from the laptop case and remove it.
    • The laptop should now be open with the RAM and wifi chip now accessible.
  3. Locate the wifi chip.
    • Locate the wifi chip.
  4. %Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
  5. Remove the 5 mm Phillips #1 screw holding the wifi chip in place. Carefully remove the wifi chip.
    • Remove the 5 mm Phillips #1 screw holding the wifi chip in place.
    • Carefully remove the wifi chip.
  6. Remove the 8, 9 mm Phillips #1 screws holding the panel in place.
    • Remove the 8, 9 mm Phillips #1 screws holding the panel in place.
  7. Flip the computer over, and with a spudger, remove the black panel directly below the keyboard. Remove the panel and flip it up onto the keyboard
    • Flip the computer over, and with a spudger, remove the black panel directly below the keyboard.
    • Remove the panel and flip it up onto the keyboard
  8. With the panel removed, locate the USB port ribbon cable connecting to the motherboard. Carefully disconnect the ribbon cable.
    • With the panel removed, locate the USB port ribbon cable connecting to the motherboard.
    • Carefully disconnect the ribbon cable.
  9. Unscrew the 5 mm Phillips #1 screw holding the USB ports in place.
    • Unscrew the 5 mm Phillips #1 screw holding the USB ports in place.
  10. The USB ports can now be removed from the laptop.
    • The USB ports can now be removed from the laptop.
6 autre(s) ont terminé cette réparation.
Ryan Holland
Membre depuis le 15/04/2014
383 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 8-8, Regan Spring 2014 Membre de l'équipe Cal Poly, Team 8-8, Regan Spring 2014
CPSU-REGAN-S14S8G8
4 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 34
Total : 3,823
