Aller au contenu principal
Acer Aspire V5-122P-0468 Hard Drive Replacement
Ce dont vous avez besoin
  1. Acer Aspire V5-122P-0468 Hard Drive Replacement, Battery: étape 1, image 1 de 2 Acer Aspire V5-122P-0468 Hard Drive Replacement, Battery: étape 1, image 2 de 2
    • Remove the nine 4mm screws with a PH0 screwdriver.
    • Remove the two 6mm screws with a PH0 screwdriver.
  2. Acer Aspire V5-122P-0468 Hard Drive Replacement: étape 2, image 1 de 2 Acer Aspire V5-122P-0468 Hard Drive Replacement: étape 2, image 2 de 2
    • Remove the black rubber tab on the back of the computer
    • Remove the 4mm screw hidden underneath the black tab with a PH0 screwdriver.
  3. Acer Aspire V5-122P-0468 Hard Drive Replacement: étape 3, image 1 de 2 Acer Aspire V5-122P-0468 Hard Drive Replacement: étape 3, image 2 de 2
    • Orient the computer upside down, with the hinges facing away from you.
    • Find the black plastic piece in the SD card slot on the right side of the computer.
    • Remove the plastic piece by sliding it out of the SD card slot.
  4. Acer Aspire V5-122P-0468 Hard Drive Replacement: étape 4, image 1 de 3 Acer Aspire V5-122P-0468 Hard Drive Replacement: étape 4, image 2 de 3 Acer Aspire V5-122P-0468 Hard Drive Replacement: étape 4, image 3 de 3
    • Insert a spudger at these eight locations to disengage the plastic tabs from the housing cover, and pry apart.
    • Continue around the entire perimeter of the cover with the spudger.
    • Use a spudger to pry the cover around I/O ports.
  5. Acer Aspire V5-122P-0468 Hard Drive Replacement: étape 5, image 1 de 3 Acer Aspire V5-122P-0468 Hard Drive Replacement: étape 5, image 2 de 3 Acer Aspire V5-122P-0468 Hard Drive Replacement: étape 5, image 3 de 3
    • Remove the two 4mm screws using a PH0 screwdriver.
    • Depress the tabs holding the battery with a spudger.
    • Disconnect the battery connector from the motherboard using a spudger.
    • Pull the battery up and away from the laptop to remove.
  6. Acer Aspire V5-122P-0468 Hard Drive Replacement, Hard Drive: étape 6, image 1 de 3 Acer Aspire V5-122P-0468 Hard Drive Replacement, Hard Drive: étape 6, image 2 de 3 Acer Aspire V5-122P-0468 Hard Drive Replacement, Hard Drive: étape 6, image 3 de 3
    • Use a plastic opening tool to pop the latch up on the ZIF connector up.
    • Pull out the ribbon cable to disconnect it from one side.
    • The cable can be left connected to the other side.
    • Remove the black isolation pad.
  7. Acer Aspire V5-122P-0468 Hard Drive Replacement: étape 7, image 1 de 2 Acer Aspire V5-122P-0468 Hard Drive Replacement: étape 7, image 2 de 2
    • Disconnect the data connector from the motherboard using a plastic opening tool.
  8. Acer Aspire V5-122P-0468 Hard Drive Replacement: étape 8, image 1 de 1
    • Remove three 4mm Phillips #0 screws.
    • Remove hard drive with rail attached from laptop.
  9. Acer Aspire V5-122P-0468 Hard Drive Replacement: étape 9, image 1 de 2 Acer Aspire V5-122P-0468 Hard Drive Replacement: étape 9, image 2 de 2
    • Remove the four 3mm Phillips #0 screws located on the side of the rails.
    • Separate the hard drive from the mounting rail.
2 autres ont terminé cette réparation.
Nat McCormick
Membre depuis le 02/15/18
801 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S16-G1, Boczar Spring 2018 Membre de l'équipe USF Tampa, Team S16-G1, Boczar Spring 2018
USFT-BOCZAR-S18S16G1
5 membres
10 tutoriels rédigés
Un commentaire
What would be the correct hard drive upgrade. Something to make this laptop faster mines the 500gb the processor is and dual core prossee a4-1250
Lara Mcneese - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 16
Total : 2,369
