Aller au contenu principal
Acer Aspire V5-122P-0468 Touchpad Replacement
Ce dont vous avez besoin
  1. Acer Aspire V5-122P-0468 Touchpad Replacement, Battery: étape 1, image 1 de 2 Acer Aspire V5-122P-0468 Touchpad Replacement, Battery: étape 1, image 2 de 2
    • Remove the nine 4mm screws with a PH0 screwdriver.
    • Remove the two 6mm screws with a PH0 screwdriver.
  2. Acer Aspire V5-122P-0468 Touchpad Replacement: étape 2, image 1 de 2 Acer Aspire V5-122P-0468 Touchpad Replacement: étape 2, image 2 de 2
    • Remove the black rubber tab on the back of the computer
    • Remove the 4mm screw hidden underneath the black tab with a PH0 screwdriver.
  3. Acer Aspire V5-122P-0468 Touchpad Replacement: étape 3, image 1 de 2 Acer Aspire V5-122P-0468 Touchpad Replacement: étape 3, image 2 de 2
    • Orient the computer upside down, with the hinges facing away from you.
    • Find the black plastic piece in the SD card slot on the right side of the computer.
    • Remove the plastic piece by sliding it out of the SD card slot.
  4. Acer Aspire V5-122P-0468 Touchpad Replacement: étape 4, image 1 de 3 Acer Aspire V5-122P-0468 Touchpad Replacement: étape 4, image 2 de 3 Acer Aspire V5-122P-0468 Touchpad Replacement: étape 4, image 3 de 3
    • Insert a spudger at these eight locations to disengage the plastic tabs from the housing cover, and pry apart.
    • Continue around the entire perimeter of the cover with the spudger.
    • Use a spudger to pry the cover around I/O ports.
  5. Acer Aspire V5-122P-0468 Touchpad Replacement: étape 5, image 1 de 3 Acer Aspire V5-122P-0468 Touchpad Replacement: étape 5, image 2 de 3 Acer Aspire V5-122P-0468 Touchpad Replacement: étape 5, image 3 de 3
    • Remove the two 4mm screws using a PH0 screwdriver.
    • Depress the tabs holding the battery with a spudger.
    • Disconnect the battery connector from the motherboard using a spudger.
    • Pull the battery up and away from the laptop to remove.
  6. Acer Aspire V5-122P-0468 Touchpad Replacement, Touchpad: étape 6, image 1 de 1
    • Use the spudger to pop up the latch on the ZIF connector.
    • Pull out the ribbon cable.
  7. Acer Aspire V5-122P-0468 Touchpad Replacement: étape 7, image 1 de 3 Acer Aspire V5-122P-0468 Touchpad Replacement: étape 7, image 2 de 3 Acer Aspire V5-122P-0468 Touchpad Replacement: étape 7, image 3 de 3
    • Remove the three 2mm PH #0 screws.
    • Lift the metal tape up and off of the mounting bracket.
  8. Acer Aspire V5-122P-0468 Touchpad Replacement: étape 8, image 1 de 1
    • Remove the metal mounting bracket from the bottom of the touchpad
  9. Acer Aspire V5-122P-0468 Touchpad Replacement: étape 9, image 1 de 2 Acer Aspire V5-122P-0468 Touchpad Replacement: étape 9, image 2 de 2
    • Carefully remove the foam pad from along the top edge of touchpad using a spudger.
    • This pad can be reused.
    • Remove the four 2mm PH #0 screws.
  10. Acer Aspire V5-122P-0468 Touchpad Replacement: étape 10, image 1 de 1
    • Remove the touchpad from the laptop using a spudger.
Nat McCormick
Membre depuis le 02/15/18
801 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S16-G1, Boczar Spring 2018 Membre de l'équipe USF Tampa, Team S16-G1, Boczar Spring 2018
USFT-BOCZAR-S18S16G1
5 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 37
Total : 1,745
